Sphere and plane intersection produces a circle
2 replies · 6K views
hq1330
Consider the intersection of the sphere (x-3)^2+(y+2)^2+(z-1)^2=13 with the plane x+y=0
a) This intersection should be a familiar curve. Describe the curve.
b) Substituing x=-y or y=-x into the equation of the sphere does not give this curve. Explain the difference.
I know that the intersectionis a circle but I am having trouble proving that. I rearranged the above equation and set it equal to x+y:
(x-3)^2+(y+2)^2+(z-1)^2-13=x+y
The next thing I did was put the like terms together to give the following equation:
x^2-6x+9-x+y^2+4y+4+y+z^2-2z+1-13=0
I then simplified this equation:
X^2-7x+9+y^2+3y+4+(z-1)^2-13=0
Now I am stuck. This just looks like a smaller sphere.
Also, I would plug in x=-y or vice versa but the second part of the question says that will not give me the result that I want.
The intersection of a sphere and a plane will be one of the following.
  1. The empty set (the two don't actually intersect).
  2. A single point.
  3. A circle.
Hi hq1330! :smile:
(try using the X2 tag just above the Reply box :wink:)
I think this question is unnecessarily obscure. :frown:
A curve, in three dimensions, requires two equations to describe it, so of course substituing x=-y or y=-x into one equation, which will only give one equation, cannot give the curve.
(in fact, it will give the two-dimensional projection of the curve onto the xz or yz plane)
Sooo … plug away! :smile:
(also, the method you used gives a whole surface, including eg the intersection of the sphere (x-3)2+(y+2)2+(z-1)2=14 with the plane x+y=1, doesn't it? :wink:)
