Sphere describing a circle, find tension
7 replies · 2K views
Apprentice123
A sphere of 3 kg describe a circle with a horizontal speed of 1,2 m/s. Knowing that L = 800 mm, determine (a) the angle theta (b) the tension in the wire
Answer:
(a) 24,2°
(b) 32,3 N
I find 2 equations
ZFn = m . an
T - Pcos(theta) = m . v^2/p
ZFt = m . at
Psin(theta) = m . at
As calculated at? (tangential acceleration)
Apprentice123 said:
… I find 2 equations
ZFn = m . an
ZFt = m . at
Hi Apprentice123! :smile:
(I can't see the diagram yet, but I assume this is a string of length 800 mm with a sphere on the end rotating at a steady speed)
i] there is no tangential acceleration … the acceleration is purely radial (centripetal)
ii] you must balance the centripetal acceleration the weight and the tension, by taking components both horizontally and vertically …
try again! :smile:
try again! :smile:
The two formulas that I found are:
ZFn = m . an
ZFt = m . at
Psin(theta) = m . dv/dt
Apprentice123 said:
ZFt = m . at
Apprentice123, there are no tangential forces, and no acceleration! :rolleyes:
v is constant!
You need vertical components, not tangential ones.
What is the vertical acceleration, and what are the vertical forces? :smile:
ZFn = m . an
(btw, I've been wondering for ages … in what language does P stand for weight? :confused: :wink:)
(oh, and have a theta for copying: θ :wink:)
T needs a θ also, and you need to write p in terms of L.
v is constant!
Correct ?
ZFn = m.an
T - P = m . v^2/L
T = 34,83 N
ZFt = m.at
at = 0
Tcos(theta) - P = 0
theta = 30,9°
Apprentice123 said:
Correct ?
... = m . v^2/L
The centripetal acceleration is m*v2/r.
But r in this case is not L. It is the radius about the point that it rotates, and that point is not where the string is tied.
Hi Apprentice123! :wink:
Now I see where you got this from …
Apprentice123 said:
ZFn = m . an
Yes, that would be correct if the centripetal acceleration were along the string (the P has cosθ, and the T has no θ).
But, as LowlyPion :smile: points out, it's horizontal.
Centripetal acceleration has nothing to do with physics, it's just geometry
never mind why it's going in a circle (in this case, because of the string) …
all that matters is the shape of the circle, and the speed …
it's a horizontal circle, so the centripetal acceleration is also horizontal. :smile:
Ok. Thanks
