Earth Spinning: What Would Happen If You Were Left Behind?
  • Context: Undergrad
  • Thread starter Thread starter HeWhoCeases
    Earth Spinning
The discussion centers on the hypothetical scenario of a person being momentarily detached from the Earth's rotational momentum. If this occurs, the individual would experience extreme forces, with westward-moving terrain impacting them at speeds of approximately 463 m/sec. The consequences vary based on geographical location; near the equator, the impact would be catastrophic, while at higher latitudes, the effects would be less severe. Additionally, the structural integrity of vessels at sea would be compromised due to dynamic pressure, potentially leading to catastrophic failure.
  • Understanding of Earth's rotational speed and its effects on objects.
  • Knowledge of dynamic pressure calculations in fluid mechanics.
  • Familiarity with hull integrity and pressure limits in marine engineering.
  • Basic principles of momentum and impulse in physics.
  • Research the effects of Earth's rotation on objects at different latitudes.
  • Learn about dynamic pressure calculations and their applications in fluid dynamics.
  • Investigate hull integrity standards for various types of marine vessels.
  • Explore the principles of momentum and impulse in classical mechanics.
Physicists, marine engineers, safety analysts, and anyone interested in the effects of rotational dynamics on physical objects.
HeWhoCeases
Ok now I have a strange question. The Earth is spinning continuously at a considerable speed. So if the Earth stopped spinning everything would be thrown by its momentum. But what would happen if for a split second you were no longer caught up in the Earths momentum. For example you are standing in the middle of a field and for one second the Earth keeps spinning, but you don't spin along with it.
Anything west of you that keeps moving will hit you at up to about 40 Mm/day = 463 m/sec.
If you are going to try it, make sure you are 463 metres from the western barbed wire fence, prickly hedge or cattle.
If you are facing west at the start of the second, you will fall on your face as your ankles break due to the supersonic surface speed. But to lie down would be good, because the wind from the west will also be supersonic, which will singe your eyebrows, strip your cloths and fill your lungs to bursting = air embolism = stroke.
All things are relative, all relatives are things, your relatives would get your things.
The consequences are less dire if you're farther away from the equator; a few tens of kilometers from the poles and you'd just experience a gentle breeze and the odd experience being chased by slow-moving terrain.
However, the point about relatives is well-taken... Perhaps I should change my will?
There are planes which can do it, even at the equator. Nothing special happens, unless you hit something.
It would need to have pretty good acceleration and brakes to do it for just one second.
Hahaha!
Depending on the local geography, you will with either end up in mid air, or else will end up as messy stain on a nearby hill.
If the local geography near your field is absolutely flat like say the Netherlands, then you might get away with just your legs missing.
If you were onboard a good ship at sea, you'd be pretty safe though.
Assuming in the first place that the good ship also stopped moving at the same instant as you.
Being at sea would worry me in those conditions. The hull speed of a boat is related to it's length and the wave making characteristics. In the region of the hull speed, the bow lifts and the stern settles into a hole below sea level. The view from the stern of a destroyer at top speed can be intimidating as you are below sea level with the stern wave breaking above you. More power will not push you much faster, it will just make the bow wave higher and the hole deeper until you sink stern first.
The percussion wave from a sea mine destroys hulls efficiently. I expect the dynamic pressure of water against the hull at Earth rotation speed would destroy the hull integrity and remove the propellers pretty much instantly.
If you were heading west as you stopped, the dynamic pressure of the moving water on the bow would become;
Pa = ½ · 1000 kg/m3 · v2.
At latitude 45°, the water speed will be about 0.7071 * 40k km/day = 1600 km/hour = 445 m/sec.
That gives a dynamic pressure of; Pa = 100 MPa = 14,500 psi or 1000 atmospheres.
Better you than me.
They would ring the Lutine Bell at Lloyd's in London only once.
https://en.wikipedia.org/wiki/HMS_Lutine_(1779)#The_Lutine_Bell
Better you than me.
Oh sorry everyone, I misread the OP in haste. I thought the question was what happens when the Earth stops rotating for 1s (which is what is typically asked) - in this case, being onboard the ship would be the same as riding a tsunami. In the case of the OP scenario: You're completely right, the passenger would be dead.
Why? Well, simple. m*dv = f*dt => if you're on board, for example, the Queen Mary, and heading north/south at the equator, your ship will receive an impulse of roughly 300*20*100*10^6Ns = 6*10^11 Ns, which will correspond to roughly a velocity of 6*10^11Ns/(150*10^3*10^3kg) = 400 m/s => you'll be turned into mush as you hit one of the walls. Obviously, if you're heading east/west wouldn't help matters much either.
PS: And by the way, you're totally right that hull integrity would be completely lost. A modern submarine can only take about 7MPa of pressure before being crushed (crush depth =700m => P = 700m*1000kg/m^3*10N/kg), and these things are custom-built to withstand pressure.
If a supertanker was found on the floor of the Atlantic, at latitude 45°, with the front 445 m crushed flat, would we entertain for even one second, the idea that the ship had suffered a 1 second loss of momentum, while on a course due west ?
  • · Replies 39 ·
  • · Replies 34 ·
14K
