Splitting Fields: Anderson and Feil, Theorem 45.4
6 replies · 3K views
Math Amateur
MHB
I am reading Anderson and Feil - A First Course in Abstract Algebra.
I am currently focused on Ch. 45: The Splitting Field ... ...
I need some help with some aspects of the proof of Theorem 45.4 ...
Theorem 45.4 and its proof read as follows:View attachment 6677
My questions on the above proof are as follows:Question 1In the above text from Anderson and Feil we read the following:"... ... This means that $$f = ( x - \alpha)^k g$$, where $$k$$ is an integer greater than $$1$$ and $$g$$ is a polynomial over $$K$$ ... ... Since $$f$$ is in $$F[x]$$ ... that is $$f$$ is over $$F$$ ... shouldn't g be over $$F$$ not $$K$$?
(I am assuming that f being "over $$F$$" means the coefficients of $$f$$ are in $$F$$ ... )
Question 2In the above text from Anderson and Feil we read the following:"... ... We then have that $$x - \alpha$$ is a factor of both $$f$$ and $$f'$$. But if we use term-by-term differentiation instead, it is clear that $$f'\in F[x]$$. ... ... "What do Anderson and Feil mean by term-by-term differentiation in this context ... ... and if they do use term-by-term differentiation (what ever they mean) how does this show that $$f'\in F[x]$$ ... ... ?
Hope someone can help ...
Help will be much appreciated ... ...
Peter
If $g$ were a polynomial over $F$, then $f$ would be reducible in $F[x]$, contrary to assumption.
They mean to differentiate each summand in the standard form of $f$. So if $f(x) = c_0 + c_1x + \cdots + c_n x^n$, then you are to compute $Df$ by computing the derivative of each summand $c_i x^i$ ($0 \le i \le n$). This would give a polynomial in $F[x]$ of lesser degree than that of $f$.
Euge said:
If $g$ were a polynomial over $F$, then $f$ would be reducible in $F[x]$, contrary to assumption. They mean to differentiate each summand in the standard form of $f$. So if $f(x) = c_0 + c_1x + \cdots + c_n x^n$, then you are to compute $Df$ by computing the derivative of each summand $c_i x^i$ ($0 \le i \le n$). This would give a polynomial in $F[x]$ of lesser degree than that of $f$.
Thanks for the help Euge ...You write:"... ... If $g$ were a polynomial over $F$, then $f$ would be reducible in $F[x]$, contrary to assumption. ... ... But ... ... ... couldn't $$g$$ have it's coefficients in $$F$$ ... but possesses no root in $$F$$ ... and still be irreducible in $$F[x]$$ ... why is this not possible ... ?
Can you help further ...?
Peter
Since $k >1$, $x - \alpha$ would be a proper factor of $f$.
Thanks Euge ... but I still do not follow ... sorry ... probably being slow to catch on ...
I am having difficulties seeing the link between k > 1 and f being reducible in F[x] and g being over K (or F) ...
Are you able to clarify ...
Again ... apologies for not following your points ...
Peter
Sorry, I made a slight error, assuming $\alpha\in F$. It's by definition of $\alpha$ being a repeated root in $K$ that $f(x)$ can be expressed as $(x - \alpha)^k g(x)$ for some $g(x)\in K[x]$ and integer $k > 1$. So while it's possible that $g(x)\in F[x]$ (as $F[x]\subset K[x]$), it is not necessarily true that $g(x)\in F[x]$.
Thanks Euge ...
Appreciate all your help ...
Peter
