Spring launcher firing steel balls
The discussion revolves around a physics problem involving a spring-loaded launcher that fires steel ball bearings with a mass of 0.22 kg. The spring is compressed by 15 cm and 20 cm in two separate scenarios, leading to different maximum heights and distances traveled. Key equations include potential energy (PE = 1/2 Kx^2) and kinetic energy (KE = 1/2 mv^2), emphasizing the conservation of energy principle. Participants are encouraged to visualize the problem and apply these equations to determine the projectile's speed and distance from the table's base.
  • Understanding of potential energy and kinetic energy equations
  • Familiarity with the conservation of energy principle
  • Basic knowledge of projectile motion
  • Ability to perform calculations involving mass, height, and distance
  • Calculate the speed of the ball bearing as it leaves the launcher using PE and KE equations
  • Analyze the projectile motion to determine the horizontal distance traveled from the table
  • Explore the effects of varying spring compression on projectile height and distance
  • Review concepts of energy conservation in mechanical systems
Students studying physics, educators teaching mechanics, and anyone interested in understanding projectile motion and energy conservation principles.
carmenmaki
A small spring-loaded launcher is designed to fire steel ball bearings with masses of 0.22 kg. When setting the launcher, you compress the spring a distance of 15 cm. You then fire the launcher straight up and find that the projectiles reach a maximum height of 0.9 m above the point that they leave the launcher. You load another ball bearing, compress the spring a distance of 20 cm, and place it horizontally at the edge of a table that is 0.5 m
tall.
You fire the ball from the edge of the table. How far from the base of the table does it hit the ground?
PE = 1/2 Kx^2
KE = 1/2 mv^2
i have no idea
carmenmaki said:
Homework Statement: A small spring-loaded launcher is designed to fire steel ball bearings with masses of 0.22 kg. When setting the launcher, you compress the spring a distance of 15 cm. You then fire the launcher straight up and find that the projectiles reach a maximum height of 0.9 m above the point that they leave the launcher. You load another ball bearing, compress the spring a distance of 20 cm, and place it horizontally at the edge of a table that is 0.5 m
tall.
Relevant Equations: PE = 1/2 Kx^2
KE = 1/2 mv^2
i have no idea
"I have no idea" doesn't work here. You must give a reasonable attempt to show that you have and/or are thinking about it.
Start with what you do know, or even an outline/diagram of what you think you have to figure out. “Drawing it out” is usually of some good value in the problem solving strategy.
carmenmaki said:
i have no idea
That just means that your first step is to get an idea. They wouldn’t have assigned you this problem if it didn’t have something to do with the material you’ve been asked to study, so go back and look at that. “You compress the spring a distance of 15cm”…. Somewhere in that material you’ll see how to relate a force applied over a distance to energy…. And you already have the kinetic and potential energy equations… and you know that energy is conserved so once the ball is in the air its total energy is conserved…. Can you calculate the speed and height of the balls as a function of time?
You can do this. And if you try and find yourself stuck we can help you get unstuck, but you have to try.
  • · Replies 18 ·
  • · Replies 52 ·
