Square of the exterior derivative
  • Context: Graduate
  • Thread starter Thread starter spaghetti3451
    Derivative Square
The discussion centers on the properties of the exterior derivative, specifically the assertion that ##\text{d}^{2}=\text{d}\wedge\text{d}## and the implications of ##\text{d}^2=0## as a defining characteristic of the exterior derivative. Participants clarify that while ##\text{d}^2=0## can be derived from the assumption of linearity, it is a fundamental property of differential forms in the context of calculus on manifolds. The discussion also distinguishes between differential geometry, which often involves metrics, and differential topology, which does not require them.
  • Understanding of exterior derivatives in differential geometry
  • Familiarity with differential forms and their properties
  • Knowledge of chain complexes in algebraic topology
  • Basic concepts of calculus on manifolds
  • Study the properties of differential forms in calculus on manifolds
  • Explore the concept of chain complexes in algebraic topology
  • Learn about the differences between differential geometry and differential topology
  • Investigate the role of metrics and connections in Riemannian geometry
Mathematicians, physicists, and students of differential geometry and topology seeking a deeper understanding of the properties and applications of exterior derivatives and differential forms.
spaghetti3451
Is ##\text{d}^{2}=\text{d}\wedge\text{d}## a definition of the exterior algebra, or can it be derived from more fundamental mathematical statements?
I'm sorry if I'm mistaken as it has been a while since I've done differential geometry, but isn't ##\text{d}^2=0## one of the defining properties of the exterior derivative?
What about the the Hodge star squared?
I know that ##**=-1##, but is this a definition, or can it be proved in two to three lines?
That is neither a definition nor is it is true in general. For ##n##-dimensional space and for a ##p##-form, ##** = -(-1)^{p(n-p)}## in Minkowski space and ##** = (-1)^{p(n-p)}## in Euclidean space.
Yes although one can derive this from the assumption that d##^{2}=0## on functions.
The condition d##^{2}=0## makes the differential forms on a manifold into what is called a "Chain Complex". Chain complexes occur all over in mathematics. The definition is that d is linear and its square is zero.
BTW: Differential forms and exterior derivatives do not require the idea of a metric so they are not specifically restricted to Differential Geometry but rather to Calculus on Manifolds.
... and geometry, topology, and (homological) algebra.
I said it badly. The least amount of structure one needs to talk about differential forms is calculus in manifolds. A metric is added structure.
I was not aware that differential geometry required a metric? Wouldn't that fall under Riemannian geometry, or Semi-Riemannian geometry?
Geometry to me means measurement of angles at least and usually also distance. These ideas are not needed to do calculus. Differential forms are just calculus. For instance one can integrate a differential form on a smooth manifold that has no shape and is just a bunch of smoothly overlapping coordinate charts..
Classical differential geometry always uses the metric induced by an embedding of a manifold in Euclidean space. It is the study of the induced metric relations.
One thing that is often missed because of the way calculus is taught using inner products in Euclidean space is that no inner product is needed and that the same derivatives can be taken with or without a metric. The subject of Differential Topology - not Differential Geometry - relies on calculus without using any metric.
This is what I have:
##*(*F)_{i_{1},i_{2},\dots, i_{n-k}}##
##= *\left(\frac{1}{k!}F^{j_{1},\dots,j_{k}}\sqrt{|\text{det}\ g|}\ \epsilon_{j_{1},\dots,j_{k},i_{1},i_{2},\dots, i_{n-k}}\right)##
##= *\left(\frac{1}{k!}F_{l_{1},\dots,l_{k}}g^{l_{1},\dots,l_{k},j_{1},\dots,j_{k}}\sqrt{|\text{det}\ g|}\ \epsilon_{j_{1},\dots,j_{k},i_{1},i_{2},\dots, i_{n-k}}\right)##
##= *\left(\frac{1}{k!}F_{l_{1},\dots,l_{k}}\sqrt{|\text{det}\ g|}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}\right)##
##= \frac{1}{k!}\left(*F_{l_{1},\dots,l_{k}}\right)\sqrt{|\text{det}\ g|}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}##
##= \frac{1}{k!}\left(\frac{1}{(n-k)!}F^{m_{1},\dots,m_{n-k}}\sqrt{|\text{det}\ g|}\ \epsilon_{m_{1},\dots,m_{n-k},l_{1},\dots,l_{k}}\right)\sqrt{|\text{det}\ g|}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}##
##= \frac{1}{k!}\left(\frac{1}{(n-k)!}F_{j_{1},\dots,j_{n-k}}g^{j_{1},\dots,j_{n-k},m_{1},\dots,m_{n-k}}\sqrt{|\text{det}\ g|}\ \epsilon_{m_{1},\dots,m_{n-k},l_{1},\dots,l_{k}}\right)\sqrt{|\text{det}\ g|}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}##
##= \frac{1}{k!}\left(\frac{1}{(n-k)!}F_{j_{1},\dots,j_{n-k}}\sqrt{|\text{det}\ g|}\ {\epsilon^{j_{1},\dots,j_{n-k}}}_{l_{1},\dots,l_{k}}\right)\sqrt{|\text{det}\ g|}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}##
##= \frac{1}{k!}\ \frac{1}{(n-k)!}\ F_{j_{1},\dots,j_{n-k}}\ |\text{det}\ g|\ {\epsilon^{j_{1},\dots,j_{n-k}}}_{l_{1},\dots,l_{k}}\ {\epsilon^{l_{1},\dots,l_{k}}}_{i_{1},i_{2},\dots, i_{n-k}}##
##= \frac{1}{(n-k)!}F_{j_{1},\dots,j_{n-k}}|\text{det}\ g|\ \delta^{j_{1},\dots,j_{n-k}}_{i_{1},\dots,i_{n-k}}##
##= \frac{1}{(n-k)!}F_{i_{1},\dots,i_{n-k}}|\text{det}\ g|##
How do I proceed next?
If you include as Differential Geometry the study of connections which are not compatible with any metric then yes you are right. Perhaps I should have said a connection rather than a metric. But the point is the same. Differential forms exist on any smooth manifold whether or not there is a connection or a metric. There is nothing about them that requires either. Differential Topology does not assume connections.
Some people have told me that they consider tensor fields as part of Differential Geometry. And maybe when one learns General Relativity tensors are introduced for the first time. But tensors like differential forms do not require a semi-Riemannain metric or in fact any metric or connection.
  • · Replies 29 ·
