Square root of Dirac Delta function
1 reply · 8K views
ismaili
I wonder how to deal with the square root of Dirac Delta function, [tex]\sqrt{\delta(x)}[/tex]. Actually, this comes from a problem which asking readers to calculate the wave function of a free particle and of a harmonic oscillator at time [tex]t[/tex], provided that the wave function at time [tex]t=0[/tex] is given, i.e. [tex]\psi(x,t=0) = \sqrt{\delta(x-a)}[/tex].
The way to obtain [tex]\psi(x,t)[/tex] in this problem is by the integral with the propagators.
However, I have no idea how to deal with [tex]\sqrt{\delta(x)}[/tex].
[tex]\sqrt{\delta(x)}=?[/tex]
I tried to differentiate it,
[tex]\frac{d}{dx}\sqrt{\delta(x)} = \frac{1}{2\sqrt{\delta(x)}}\delta'(x)<br /> = -\frac{1}{2\sqrt{\delta(x)}}\frac{\delta(x)}{x} = -\frac{1}{2}\frac{\sqrt{\delta(x)}}{x}[/tex]
[tex]\Rightarrow <br /> \int \sqrt{\delta(x)}f(x)dx = -2\int xf(x)d(\sqrt{\delta(x)}) [/tex]
But this is still no good...
I also tried the other definition of Dirac Delta function,
[tex]\delta(x)\sim\lim_{\epsilon\rightarrow 0}e^{-x^2/\epsilon}[/tex]
[tex]\Rightarrow \sqrt{\delta(x)} = \lim_{\epsilon\rightarrow 0}e^{-x^2/2\epsilon}<br /> =\lim_{\epsilon'\rightarrow 0}e^{-x^2/\epsilon'} = \delta(x) ??[/tex]
still no good...
I also tried to calculate [tex]\psi(x,t)^2[/tex] to try to get rid of the square root,
but it seems doesn't help.
Is there anyone who has any ideas about [tex]\sqrt{\delta(x)}[/tex] ?
Any help will be appreciated, thanks.
still no good...
I have an idea, but I'm not sure if it's correct.
Consider
[tex]f(0) = \int \delta(x)f(x)dx = \int \sqrt{\delta(x)}\sqrt{\delta(x)} f(x)dx<br /> = \int \sqrt{\delta(x)}\sqrt{\delta(x)} dg(x)[/tex]
where
[tex]\frac{dg}{dx} = f[/tex]
,then integration by part gives,
[tex]f(0) = -2\int g(x)\frac{\delta'(x)}{2\sqrt{\delta(x)}} dx <br /> = \int g(x) \frac{\sqrt{\delta(x)}}{x} dx[/tex]
Now, let [tex]g(x) = xh(x)[/tex], we have,
[tex]f(0) = \int h(x)\sqrt{\delta(x)} dx[/tex]
,i.e.
[tex] \int h(x)\sqrt{\delta(x)} dx = \left[h(x) + xh'(x)\right]_{x=0}[/tex]
I'm not sure if I were correct.
Any help would be appreciated!
Gosh, I found one mistake just now,
I calculated the integration by part wrong,
I omitted one factor of [tex]\sqrt{\delta(x)}[/tex]
So the final formula is incorrect.
