Squaring an Integral of a function
The discussion centers on the identity involving the square of the Gaussian integral, specifically the expression for squaring an integral of a function. Participants clarify that the integral can be treated as a number, allowing it to be squared, and that the dummy variable used in the integration can be renamed without affecting the result. The confusion arises from the limits of integration, with emphasis on the symmetry of the Gaussian function, which allows for integration from zero to infinity to yield half the total area. Additionally, the standard computation of the Gaussian integral utilizes polar coordinates over the entire plane, which contributes to the misunderstanding. Understanding these aspects clarifies the reasoning behind the identity in question.
occh
In the proof of the closed form of the Gaussian Integral the expression$${(\int_{-\infty}^\infty f(x)dx)}^2= \int_0^\infty f(x)dx+\int_0^\infty f(y)dy $$ appears. I have seen it multiple places and understand this step is justified, but I cannot find a theorem for it anywhere. Can anybody explain the reasoning behind this identity?
It is not true the way you have written it down. Did you mean to write the following?
\left(\int_{-\infty}^\infty f(x) dx \right)^2 = \left(\int_{-\infty}^\infty f(x) dx \right)\cdot \left(\int_{-\infty}^\infty f(y) dy \right)
Yeah definitely multiplied, but I'm nearly positive that the RHS bottom limits are 0.
Regardless, my question still holds, where does this identity come from (in whatever form it actually has)
Well, the integral is just a number:
I = \int_{-\infty}^\infty f(x) dx
which you can square, which results in a multiplication ##I\cdot I##. The variable ##x## is just a dummy variable which is being integrated over and you can call it ##y## in the second term. If you call it ##x## in the second term you may run into trouble because you just named two different dummy variables the same thing, if you name it ##y##, everything in the first integral is constant wrt ##y## and you can move it inside the second integral without problem.
Likes occh
Great, thanks!
If the integrand is symmetric (Gaussian is), then the integral starting at 0 is 1/2 the total.
However, it should be noted that the standard computation of the Gaussian integral uses all of ##\mathbb R^2## as the integration domain and does the evaluation in polar coordinates in the ##xy##-plane. This results in a range for the radial coordinate ##r## which is 0 to ##\infty##, which I suspect is the source of the confusion in this case.
  • · Replies 19 ·
  • · Replies 20 ·
