Stability and Storage Conditions for Common Solutions | Expert Tips
  • Thread starter Thread starter asy
    Stability
The discussion centers around the stability and storage conditions for various chemical solutions, particularly in the context of preparing solutions for enzyme activity assays. Participants seek guidance on whether stock solutions can be prepared in advance or if fresh solutions are necessary for reliable results.
  • Experimental/applied
  • One participant inquires about resources for stability and storage conditions of common solutions.
  • Another suggests searching for "reagent stability" as a starting point.
  • A participant specifies the solutions they need to prepare for enzyme activity, including Hydroxylamine, Glutathione, and CBZ-L-glutaminylglycine.
  • It is proposed that a stock solution may be feasible, with recommendations to use amber volumetric flasks and store in a refrigerator, allowing the solution to reach room temperature before use.
  • One participant cites Abcam's recommendation that fresh solutions are preferable but provides guidelines for storing reduced glutathione in airtight vials at -20°C for up to one week.
  • Another participant notes the differences in stability between bio reagents and other reagents they have used.
  • A suggestion is made to prepare mixed solutions for a week's work and adjust pH as necessary, with considerations for the stability of Hydroxylamine in various forms.
  • Links to external resources are provided for further information on Hydroxylamine and its stability.
Participants express varying opinions on the best practices for preparing and storing solutions, indicating that there is no consensus on a single approach. Some suggest making stock solutions, while others emphasize the importance of using fresh solutions.
Participants mention specific storage conditions and stability factors, but there are unresolved questions regarding the best practices for different reagents and the impact of storage on experimental results.
asy
Hello everyone,
I need to know the stability and storage conditions of some solutions that I need to prepare. Is there a place where I can find this information (at least for most common solutions)? Or is there any bibliography to consult?
Thanks
Chemistry news on Phys.org
Google "reagent stability."
:p
thanks... but... Not always that easy!
Organic? Inorganic? Redox? Acid-base?
I will need to make the following for determining enzyme activity.
0.1 M Hydroxylamine; 10 mM Glutathione; 30 mM CBZ-L-glutaminylglycine
and I am trying to find out if I can make this a stock solution or if I have to make it fresh every time.
Thank you
You can probably get away with a stock solution. Use amber volumetrics, and store in a refrigerator. Allow to warm to room temp before taking alliquots. You can always store under a blanket of nitrogen as well.
@Kevin McHugh
Abcam recommends for reduced glutathione: fresh solutions are best but store in an air tight vial, one week max:
Wherever possible, you should prepare and use solutions on the same day. However, if you
need to make up stock solutions in advance, we recommend that you store the solution as
aliquots in tightly sealed vials at -20°C. Generally, these will be useable for up to one week.
Before use, and prior to opening the vial we recommend that you allow your product to
equilibrate to room temperature for at least 1 hour. [... cut]
http://www.abcam.com/Reduced-Glutathione-GSH-ab142044.pdf
I would suggest that a single storage approach might not be appropriate for everything.
Yeah, bio reagents are little different than the reagents I've commonly used. Thanks Jim.
I had slightly looked into that, thinking that you might have come back after my last related post. :frown:
I think I would, as others have recommended, make up the solutions, all the components mixed, enough for a weeks work and only change if it seems you're getting different results from one day to another. I would make up the solution containing the requisite moles of your three substances to about three quarters of the required volume, Bring to pH as said by Borek with acid or alkali, and then bring to 100% volume. Keep this stock in the fridge.
Hydroxylamine is sold as a 50% solution, and also as the hydrochloride salt and sulphate. Off the top of my head I would normally expect the salts to be more stable. But they are hygroscopic so I think they should be stocked in a desiccator, cold. Often you get some information from vendors' catalogues, and other stuff I give below for what it is worth. At any rate you will note that this stuff is classified as mildly hazardous, but just normal precautions should be okay.
For which of the sources and what form of the stuff to prefer, in the scientific publications of the other people working on your system the sources will often be stated in the 'Materials and methods' of their papers.
https://pubchem.ncbi.nlm.nih.gov/compound/hydroxylamine#section=Auto-Ignition
http://www.sigmaaldrich.com/catalog/search?term=Hydroxylamine&interface=All&N=0&mode=match partialmax&lang=it&region=IT&focus=product
https://pubchem.ncbi.nlm.nih.gov/compound/Hydroxylamine_hydrochloride#section=Decomposition
http://www.labchem.com/tools/msds/msds/LC15515.pdf
http://www.sigmaaldrich.com/catalog...=it&region=IT&gclid=CMuUroC3vM8CFS8o0wodYRYMn
