Standard Deviation: Get 10 Cents on Probability Problem
Coder74
Hey everyone!
I'm learning about some statistics and its past office hours with my teacher but I'm stuck on this problem.. I came up with 2.14% as the probabillity\final answer..
Could you guys give me your 10 cents on this?
Thanks again!
You need to convert the two raw data (called $x$) into $z$-scores:
$$z=\frac{x-\mu}{\sigma}$$
Then, use a table to find the area under th standard normal curve between the two $x$-scores to find the requested probability.
Can you proceed?
Coder74 said:
Hey everyone!
Thanks again!
Hi Coder74,
2.14% is the correct answer.
It's the probability between 2 and 3 standard deviations from the mean.
Thanks for both replies you guys I appreciate it!
However since this is an online schooling when I entered 2.14 as an answer it wouldn't register as correct..
Consulting the table in my old stats textbook, I find:
$$P(X)\approx0.4987-0.4772=0.0215$$
When I use a numeric scheme to approximate the integral I get:
$$P(X)=\frac{1}{\sqrt{2\pi}}\int_2^3 e^{-\frac{x^2}{2}}\,dx\approx0.0214002339165491$$
Perhaps this issue is you are entering a percentage, and the app is expecting the value of probability, i.e. 0.0214. :D
Thanks, Mark! As it turns out there was a glitch in the system after all.. Haha, thanks for the help everyone!
