Standard errors in surface areas and volumes?
The discussion focuses on calculating the total surface area and volume of a copper cylinder, along with their respective standard errors using error propagation formulas. The cylinder has a length of 5.82 cm with an uncertainty of 0.06 cm and a radius of 2.53 cm with an uncertainty of 0.04 cm. The relevant formulas for volume and surface area are provided, specifically V = πr²ℓ for volume and the error propagation formula δf(x₁, ..., xₙ) = √(Σ(∂f/∂xᵢ δxᵢ)²). The calculated standard error in volume is noted as 2.88.
  • Understanding of error propagation formulas
  • Familiarity with the formula for the volume of a cylinder (V = πr²ℓ)
  • Knowledge of partial derivatives in the context of multivariable functions
  • Basic concepts of uncertainty and standard error in measurements
  • Research error propagation techniques in physics and engineering
  • Learn how to apply partial derivatives in error analysis
  • Explore the calculation of surface area for different geometric shapes
  • Study the implications of measurement uncertainty in scientific experiments
Students in physics or engineering, researchers conducting experiments involving measurements, and professionals needing to apply error analysis in their calculations.
zejaa7
I have to finish this one question that I have come across and I am having a bit of trouble figuring out where to go from what I havee done.
The Q is:
A copper cylinder is 5.82 +/- 0.06 cm long and has a radius of 2.53 +/- 0.04 cm. Using the appropraite formula,
Question Details
a) Find the total surface area of the cylinder and the standard error in the area .
b) Find the volume of the cylinder and the standard error in the volume.
c) Given that the density of copper is 8.96cm^-3, find the mass of the cylinder
We are to use error propagation formulas for this.
For part a and b I calculated the normals and for b- volume and used the formulae for product rules to calculate the error in volume and found it to be 2.88.
Can someone guide me through the process because I have the formulas and I plug in the values but I am not sure If i am right or not.
Thank you.
CompuChip said:
Technically, the correct formula from error analysis is
\delta f(x_1, \cdots, x_n) = \sqrt{ \sum_{i = 1}^n \left( \frac{\partial f(x_1, \cdots, x_n)}{\partial x_i} \delta x_i \right)^2 }
where \delta x_i is the uncertainty in xi.
I prefer to remember just this formula and see how it applies in any particular problem. In this case, for example, the volume of the cilinder would be given by V = \pi r^2 \ell where r is the radius and \ell its length.
Since both of these have an uncertainty associated to them, you can calculate
\frac{\partial V}{\partial \ell} = \pi r^2, \quad \frac{\partial V}{\partial r} = 2 \pi r \ell
and simply plug in your values for r, \ell, \delta r \text{ and } \delta\ell.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
  • · Replies 16 ·
  • · Replies 56 ·
  • · Replies 22 ·
  • · Replies 30 ·
