What Frequencies Form Standing Waves in a Microwave Cavity?
The discussion centers on determining the frequencies that create standing waves in a microwave cavity, specifically a closed cylinder of length 8 cm. The fundamental frequency is calculated using the formula f = v/(4L), where v is the speed of light (3 x 108 m/s). The calculated fundamental frequency is 0.9375 GHz, and subsequent harmonics are derived by adding this value. The valid frequencies that form standing waves in the cavity include 11.25 GHz, 12.19 GHz, 13.13 GHz, 14.06 GHz, 15.00 GHz, 15.94 GHz, 16.88 GHz, and 17.81 GHz.
  • Understanding of microwave frequency ranges (10 GHz to 20 GHz)
  • Knowledge of wave mechanics and standing waves
  • Familiarity with the speed of light (3 x 108 m/s)
  • Ability to perform calculations involving harmonics and wavelengths
  • Research the principles of standing waves in closed cylindrical cavities
  • Learn about harmonic frequencies and their calculations in wave mechanics
  • Explore the application of microwave technology in various fields
  • Study the impact of cavity dimensions on resonant frequencies
Students and professionals in physics, engineers working with microwave technology, and anyone interested in wave mechanics and resonance phenomena.
holaholayo
A microwave generator can produce microwaves at any frequency between 10 GHz and 20 GHz. The microwaves are aimed, through a small hole, into a "microwave cavity" that consists of a d = 8 cm-long cylinder with reflective ends.
Select all frequencies from those tabulated below which will create standing waves in the microwave cavity.
14.06 GHz
12.19 GHz
13.13 GHz
15.00 GHz
15.94 GHz
16.88 GHz
11.25 GHz
17.81 GHz
I have a picture but its just a closed cylinder with microwaves aimed at it from a small hole on the side. Since this is a closed-closed container, the possible frequencies would be f=v/4L.
Because microwaves are used the velocity would be 3x10^8 m/s. I used the equation to calculate the fundamental frequency f=(3x10^8)/(4x0.08) then divided that by 10^9 to get them in GHz and I got f1=0.9375 GHz. I kept on adding 0.9375 to get all the other possible frequencies because they have to be in multiples of the fundamental frequency. The frequencies bigger than 10 GHz were 10.3125 11.25 12.1875 13.125 14.0625 15.00 15.9375 16.875 17.8125 18.75 19.6875 which if I rounded to 4 sig fis would include all the frequencies that were given. But if I selected all the options, it tells me that's not right. So, am I making a mistake in calculating the frequencies?
The wavelength of the nth harmonic in this case is 2L/n where L is the length of the cavity (Draw out diagrams of the first few cases and you should be able to see this for your self).
Therefore the frequency of the nth harmonic is c/(2L/n) = nc/2L.
Thanks!
...I don't know why I used f=v/4L
