Starting velocity of a electron
  • Thread starter Thread starter jonlg_uk
    Electron Velocity
The starting velocity of an electron emitted from a cathode in cathode ray tube experiments can be calculated using the equation v = [2(V-W)/511,000]½·c, where V is the accelerating potential and W is the work function (approximately 4 volts for tungsten). The cathode temperature influences the number of emitted electrons, but the velocity of each electron is not singular; it follows a distribution due to thermionic emission, with a spread of roughly 2.45 kT. The kinetic energy of the emitted electrons is derived from the difference between the applied voltage and the work function.
  • Understanding of thermionic emission principles
  • Familiarity with the concept of work function in materials
  • Knowledge of kinetic energy equations in physics
  • Basic grasp of electron behavior in electric fields
  • Research the derivation of the kinetic energy equation V - W = ½mv²
  • Study the effects of temperature on thermionic emission rates
  • Explore the energy distribution of electrons emitted from cathodes
  • Learn about the implications of work function variations in different materials
Physicists, electrical engineers, and researchers conducting experiments with cathode ray tubes or studying electron dynamics in thermionic emission contexts.
jonlg_uk
Hello, I am conducting some cathode ray tube experiments and I need to know how to calculate the starting velocity of an electron when it is emitted from a cathode. Does anyone know how to do this? Will the electron starting traveling velocity vary depending on the heat of the cathode? I know as you heat the cathode up more electrons are liberated and hence emitted.
I thank you in advance
Jon
Hi
The final velocity of the electron can be controlled by controlling the accelerating potential. The cathode temperature will determine the no: of electron/intensity of the beam.
I am not sure about calculating the starting velocity of electron but if you equate the energy required to heat up the cathode to the Kinetic Energy of the electron emitted due to thermionic emission, may be you can get the value.
Everybody: Please correct me if required.
The energy (and velocity) of the electron is reduced by the work function W (~4 volts) of the filament (probably tungsten):
http://en.wikipedia.org/wiki/Work_function
So the electron velocity is given by
where V is the voltage (potential) relative to the filament at any given location, and c is the velocity of light. There is a very small energy spread, due in part to the thermal spread in the thermionic emission energy, and Coulomb forces within the electron beam. See also
http://en.wikipedia.org/wiki/Thermionic_emission
Bob S
Bob S
Hi Bob where is this equation derived from? I can't find what equation your re-arranged to get that?
511000 eV is the electrons energy at rest ?
Kind RegardsJon
Hi Jon-
The kinetic energy of the electron is the applied voltage potential V (equivalent to electric field E times distance x) minus the filament work function W. So, using energy in electron-volt (eV) units,
V-W = ½mv2 (non-relativistic form)
where m is electron mass and v = electron velocity. Multiplying and dividing by c, the velocity of light, we get
V - W = ½·mc2·v2/c2
using the electron mass in eV units as mc2 = 511,000 eV
we get V - W = ½·511,000 eV·v2/c2
et cetera
Bob S
Hi Bob thanks for the clarification on that. Just to cure my curiosity. How do you arrive at the fact that V-W = ½mv2 ?
Read about work function at
The electrons have to be pulled out of a potential well to leave the hot cathode. The depth of this potential well varies from one element to another. See picture and table in above URL. This reduces the effective voltage (kinetic energy) of the accelerated electrons by a voltage W (in eV).
Bob S
Just one last question, if I was to exceed the work function voltage for tungsten, say I took it upto 10V. Would I get more emitted electrons but all with the same energy (all be it with a little spread)?
I don't know if people are simply missing pertinent information here, or this has been simplified way too much.
There is no one single velocity emitted via thermionic emission. It is a distribution of energy and thus, velocity. See, for example, Fig. 3 in R.D. Young, Phys. Rev. v.113, p.110 (1959). The energy distribution has a form of Eq. 28, with a spread of roughly 2.45 kT, with the peak at kT.
So your starting velocity has a spread in values!
Zz.
  • · Replies 28 ·
  • · Replies 17 ·
  • · Replies 26 ·
