Refrigerant Storage in Off System: Gas or Liquid?
The refrigerant in a refrigeration system is stored in various components, including the compressor and tubes, when the system is off. Upon shutdown, the refrigerant evaporates, raising pressure and temperature until it stabilizes at ambient levels. Depending on the coolant type, it may exist in a two-phase state or entirely as gas. Proper handling during transport is crucial, as tilting the compressor can lead to liquid refrigerant or lubricating oil entering inappropriate areas, potentially causing operational issues.
  • Understanding of refrigeration cycle principles
  • Familiarity with refrigerant types and properties
  • Knowledge of compressor functions and components
  • Awareness of pressure and temperature relationships in closed systems
  • Research the properties of different refrigerants and their phase behavior
  • Learn about compressor design and the implications of tilting during transport
  • Study the impact of refrigerant state on system efficiency and performance
  • Explore best practices for refrigerant handling and maintenance
HVAC technicians, refrigeration engineers, and anyone involved in the maintenance and operation of cooling systems will benefit from this discussion.
M.Kalai vanan
WHERE is the refrigerant stored in the refrigeration system when the system is in OFF and
in WHAT state Gas or Liquid ?
After switching off the cooling system the refrigerant evaporates, increasing the pressure in the closed system and therefore also the temperature. After a certain time the temperature of the refrigerant corresponds to the ambient temperature. Depending on the type of coolant, its state could be in the two-phase regime (at vapor pressure corresponding to the ambient temperature) or it could be entirely evaporated and the system contains only gas.
Thanks
But where will the two phase regime stay
Within the compressor or the tubes
russ_watters said:
...and it just remains in the tubes.
But once it reaches the vapor pressure, some of it becomes liquid and if so will the liquid remains in the tube ?
Sure. Where else could it go?
@ russ_watters
Why can't the liquid flow to the compressor cavity.
Why then the ac mechanics advise us not to tilt the compressor during shifting or relocating. They say it is the compressor that stores the gas during OFF.
Please expalin this part.
M.Kalai vanan said:
@ russ_watters
The refrigerant normally is stored in all parts of the cooling system (compressor, vaporizer, ...) .If the coolant is in two-phase region, part of the liquid phase could enter the compressor, if, after switching it off and turning/shifting/tilting the device, one of the valves is not tight (or even open) - this especially concerns the inlet valve, which is constructed to open, if the pressure outside of the compressor exceeds the pressure in the inside.
I think it has more to do with the possibility of the lubricating oil flooding the compressor chamber, or entering into the condenser in bulk.
If the bulk of oil is pushed along and enters the capillary tube then more problems...as it works it way through
12K
