How to Convert Mechanical System Equations to State Space Form?
To convert the given mechanical system equations into state space form, the first step is to define the state variable array X as [QL; QL'; Qm; Qm']. The derivatives QL' and Qm' can be expressed as X2' = [-JL*QL'' - k(QL - Qm)]/BL and X4' = (1/Jm)(u + k(QL - Qm) - Bm*Qm'), respectively. This approach allows for the construction of the A matrix, where the first half is determined by the relationships X1' = X2 and X3' = X4. The B matrix will contain only one nonzero element corresponding to the input from the second equation. Following these steps will yield the complete state space representation.
zoom1
JL*QL'' + BL*QL' + k(QL - Qm) = 0
Jm*Qm'' + Bm*Qm' - k(QL - Qm) = u
This is the equation set I have for a motor with a load.
QL'' means second derivative and QL' means first derivative.
I need to be able to obtain the state space representation of this model where X = [QL;QL';Qm;Qm'] (This is of course a column array)
I tried my best but couldn't obtain it.
Started off with QL' = [-JL*QL'' - k(QL - Qm)]/BL
But when I try to represent this, I don't have the QL'' term in my state variable array X, so couldn't proceed further.
How am I supposed to approach this problem ?
as you are most likely aware, state space representation is usually of the form
X'=A*X+B
Y=C*X+D
your first goal is to define your X array.
then you need to define your A and B matrix.
I would define each element of your X array.
SO you already stated
QL = X1
QL' =X2
Qm=X3
Qm'=X4
so right off the bat you know X1'=X2 and X3'=X4, that gives you half of your A matrix
So you need to find your A matrix rows for X2' and X4'.
So use equation one to solve for X2', then use equation 2 to solve for X4'. as you can see there is only one input which is in equation 2, so there will only be one nonzero element in the B matrix.
X'=A*X+B
Y=C*X+D
QL = X1
QL' =X2
Qm=X3
Qm'=X4
Perfect !
Thanks a lot
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
9K
