Static Friction and Uniform Circular Motion
The problem involves a cat on a merry-go-round, requiring the calculation of the least coefficient of static friction necessary to keep the cat in place while it moves in uniform circular motion. The context includes concepts from circular motion and friction.
  • Participants discuss the calculations for the circumference, velocity, and centripetal acceleration of the cat. There is uncertainty about how to apply the static friction formula to the calculated values. Some participants suggest using angular velocity as an alternative approach.
The discussion is active, with participants providing insights into the relationships between forces involved in circular motion and static friction. There is acknowledgment of the need for mass in certain calculations, but also suggestions that it may not be necessary for the problem at hand.
Participants note the absence of the cat's mass, which is a point of contention in determining the normal force and frictional force. The original poster expresses confusion regarding the application of formulas and the relevance of angular velocity.
harpua09
A cat sits on a merry go round at a radius of 4.0m from the center. The ride makes one complete rotation every 6.3 seconds. What is the least coefficient of static friction to keep the cat in place?
Circumference = 2Pi*r
V=d/t
a=v^2/r
I first figured out the circumference of the circle traveled by the cat to be:
2 x 4.0 x Pi= 25.13m
Velocity of the cat:
V = 25.13/6.3 = 3.99 m/s
Centripetal acceleration of the cat:
a = 3.99^2 / 4.0 = 3.98 m/s^2
I'm assuming that i have to use the formula for static friction in some way, but i am not sure how to apply it to what i have calculated so far. Any help would be greatly appreciated, thanks.
Your answer here is correct, but you could have alternatively just found ω since they said "1 revolution in 6.3s" and then use a=ω2r
Well the force of static friction is providing the centripetal force needed to keep the cat in circular motion. If the mass of the cat is 'm', then its weight is 'mg' and the normal reaction is 'N'. The frictional force is therefore F= μN.
Just equate the two and solve.
I'm not sure what you are referring to with "ω". I am also not sure hot to find N, if i do not know the mass of the cat.
Interesting. Seems like mass is indeed needed.
ω=angular velocity, you did not need to use it, but it would have just been easier instead of finding the velocity and then using v2/r
Not really. Remember, the cat is not moving upwards so the normal reaction N is just the weight 'mg'. N=mg.
and if Fcentripetal=Ffriction mass is not needed :wink:
Figured it out, thanks!
Oh, my bad. Sorry. I seem to be missing a lot lately. For some fudgy reason my head thought of the centripetal acceleration as the force (without multiplying with mass).
/facepalm
