Static Mechanics: Aircraft Nosewheel Linkage Torque
  • Thread starter Thread starter jojosg
4 replies · 3K views
jojosg
Hi I'm stuck at how to draw the free body diagram for thise nose wheel question
Moment equal 0
see attached
A free body diagram shows the forces on a single rigid body. Here you have a linkage, so you need an FBD for each moving part. This will involve defining unknowns for forces and torques between connected bodies, each such force being represented in the FBDs for both bodies.
What are the moving rigid bodies in this problem? Pick one and list the forces on it. Then post your attempt at its FBD.
I think it is safe to assume that links BC and CD are massless because no masses are given for them. Assume that the torque at M gives rise to a force ##F_D## at D that is just right to prevent the combined (arm + wheel) assembly AO from rotating either clockwise or counterclockwise.
Consider the external force and moment acting on the whole mechanism first.
One is the represented M, which is necessary to raise the combined mass of 50 kg, which can be represented as a vertical force applied at point G.
Note that the value of that vertical force will be constant, while the value of the necessary moment M will change as the wheel is being raised, reason for which the problem asks for the value of moment M at that specific position of the mechanism's stroke.
Please, see this example:
https://www.school-mechademic.com/blog/static-force-analysis-on-a-4-bar-link-mechanism
:cool:
ok I think I got it thanks everyone
