Where to Find Statics Practice Problems for Physics Re-Test Preparation?
The discussion revolves around preparation for a Physics re-test on Statics, specifically seeking practice problems that differ from textbook examples. Participants express concerns about the nature of the test and the types of problems likely to be included.
  • Participants share specific statics problems involving beams, forces, and torques, questioning the setup and calculations. Some seek clarification on the application of torque concepts and the significance of various distances in their calculations.
There is an active exchange of ideas, with participants providing feedback on each other's approaches and calculations. Some guidance is offered regarding torque calculations and the importance of identifying the center of mass. Multiple interpretations of the problems are explored, but no consensus has been reached on specific solutions.
Participants are working under the constraint of preparing for a re-test, which may influence their focus on finding non-standard practice problems. There is an acknowledgment of previous difficulties encountered in the first test, prompting a desire for varied problem types.
Shay10825
Hi I have a Physics re-test tomorrow on Statics. Since everyone failed the 1st statics test he is going to let us take another one (he's really nice :smile: ). It is not going to be like the 1st one. Where can I get some statics practice problems?? I'm doing ALL of the problems in the book but 95% of the time he does not put problems on the test like the 1s in the book (that's one of the reasons I did not do so well on the 1st test).
~Thanks
What level physics are you in?
AP Physics B
Okay straight from my physics B statics test:
1. A uniform 20.0 kg, 10.0m long beam is supported by two posts. Post A is 1.00m from an end of the beam and post B is 4.00m from the other end. A 15.00 kg cat sits on the beam directly above post B.
a)Calculate the force exerted by post A on the beam
b)Calculate force exerted by post B on the beam.
c)How far can the cat walk toward the end of the board before the board tips. The beam is not fastened to the posts.
2. A 50.0 kg uniform sign is hung from a 20.0 kg, 4.00m long uniform beam supported by a wall and a wire. The sign is a square 3.00m on a side and is hung so that the end of the sign is even with the end of the beam. The wire makes an angle of 30 degrees with the wall.
a)Find the tension in the wire.
b)Find the force exerted by the wall on the beam.
3. A 5.00m long 20.0 kg uniform ladder leans against a wall so that the top of the ladder is 4.00 m above the ground. Assume no friction between wall and ladder.
a) What force is exerted by the wall on the ladder?
b) What force is exerted by the ground on the ladder?
c)What minimum coefficient of friction between ground and ladder is required to keep the system static.
Skomatth said:
2. A 50.0 kg uniform sign is hung from a 20 kg, 4.00m long uniform beam supported by a wall and a wire. The sign is a square 3.00m on a side and is hung so that the end of the sign is even with the end of the beam. The wire makes an angle of 30 degrees with the wall.
a.) (20.9g)(4)+(50g)(3)+8(t)=0
t=286.16
b.) 286.16+ (20.9g)+(50g)+fwall = 0
fwall= 980.98
Sorry typed some wrong numbers, look at my editted post. Anyway you're not doing the problem right, I'll get back to you on that in a second.
Skomatth said:
3. A 5.00m long 20.9 kg uniform ladder leans against a wall so that the top of the ladder is 4.99 m above the ground. Assume no friction between wall and ladder.
a) (Fwall)(4.99)+(5)(20.9g)=0
Fwall = 205.23
b) 205.23+(20.9g) + fn = 0
-410.05
c) i really don't have a clue
Ok Torque counterclockwise = Torque clockwise. Is this what you're trying to do?
Pick a point to sum your torques around. I'd suggest the point where the beam touches the wall, since you don't yet know the force that the wall exerts on the beam. The beams weight acts down from the center of the beam. You have the center of mass of the sign right. The wire isn't perpendicular to the beam so only the vertical component of the tension is going to be producing torque. Remember Toque is the cross product of force and the radius vectors.
Note that the wire is attached to the beam's end opposite the wall.
Yeah
Would I do:
(20g)(2) +(50g)(3)+ 8T = 0
t= 232.75
Sorry for not reading your first post correctly but 3m isn't the cm of the sign and where is the 8 coming from?
Woops that is suppose to be 40. I did the math wrong. That is the length of the wire.
cos 60 = 20/h
h = 40
So would the answer be
(20g)(2) +(50g)(1.5)+ 40T = 0
t= 28.175
Torque= the cross product of F and R
Cross product is always F*R * sine of the lesser included angle.
So the torque from the wire is Tsin(60) * 4m The length of the wire is irrevelant here.
Is T the force?? If so would T be 20*9.8?
what would you do with the 50 kg block?
2(20g)+ (4)(50g) = 4Tsin 60
t= 678.96
Very close. You have everything correct except the radius for the sign. It's 3m long so where is its center of mass. How far away from the center of rotation is the center of mass?
It's center of mass is at 1.5 right? So what would I do with the 1.5?
The center of mass is 1.5m away from the edge of the sign as you stated. The sign is attached one end to the 4m mark and one end to the 1m mark.
2(20g)+ (4)(50g) + (5.5)(50g)= 4Tsin 60
t=1456.94
The rod is 4m long. 0-------1---------2---------3--------4
Sign is attached at 1 and at 4.
I don't know. I give up :frown:
What's the answer?
Tsin(60)*4 = 50g*2.5 + 20g* 2
T=467 N
thanks for your help :smile:
