Stationary state of two body wave function
The discussion focuses on deriving the stationary state two-body wave function, expressed as \(\Psi(\vec{r_1},\vec{r_2},t)=e^{i\vec{P}\cdot\vec{R}/\hbar}\psi_E(\vec{r})e^{-i\left[\frac{P^2}{2M}+E\right]t/\hbar}\). The user has successfully separated variables in the time-independent Schrödinger equation, resulting in equations for the center of mass and relative coordinates. They seek guidance on incorporating time into their solution, specifically how to transition from the time-independent to the time-dependent Schrödinger equation.
  • Understanding of the time-dependent Schrödinger equation
  • Knowledge of quantum mechanics concepts such as wave functions and separation of variables
  • Familiarity with center of mass and reduced mass in two-body systems
  • Proficiency in mathematical techniques for solving differential equations
  • Study the time-dependent Schrödinger equation in detail
  • Learn about the method of separation of variables in quantum mechanics
  • Investigate the role of the center of mass and reduced mass in two-body problems
  • Explore solutions to the time-independent Schrödinger equation for various potentials
Students and researchers in quantum mechanics, particularly those working on two-body problems and wave function analysis, will benefit from this discussion.
Piano man
The ultimate goal of the problem is to show that the stationary state two body wave function can be written as
So far, I have separated the variables in the time independent equation:
\Psi(\vec{r_1},\vec{r_2})=\Psi(\vec{R})\psi_E(\vec{r})
where \vec{R}=centre of mass
and \vec{r}=\vec{r_1}-\vec{r_2}
and have the two equations
\frac{-\hbar^2}{2M}\nabla^2_R\Psi(\vec{R})=E_{com}\Psi(\vec{R}) and
\left[\frac{-\hbar^2}{2\mu}\nabla^2_r+V(\vec{r})\right]\psi_E(\vec{r})=E\psi_E(\vec{r})
where M=m_1+m_2
and \mu=reduced mass
...So...what I think I have to do is write
\Psi(\vec{r_1},\vec{r_2},t)=\Psi(\vec{R})\psi_E(\vec{r})\phi(t)
and solve each equation separately, but I'm not sure how to get the answer in the first equation I wrote. For example, how do I introduce time?
Any suggestions would be great!
Start from the time dependent Schrödinger Equation, not the time independent equation.
  • · Replies 32 ·
