Statistical Physics: Proving "if p(a)=p(b)=p then p(ab) ≤ p^2
The discussion revolves around proving the statement "if p(a)=p(b)=p then p(ab) ≤ p^2" within the context of statistical physics and probability theory. Participants are exploring the implications of this statement regarding the probabilities of events a and b, and the relationship between their joint probability.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the meaning of p(ab) and whether events a and b are independent or disjoint. There are attempts to clarify the definitions and implications of the probabilities involved, as well as questions about the assumptions that can be made regarding the events.
The discussion is ongoing, with various interpretations being explored. Some participants have suggested specific cases, such as when a and b are mutually exclusive or independent, but there is no consensus on a general proof. Guidance has been offered to consider different scenarios and the implications of independence.
Participants note that the original problem lacks specific constraints or information about the relationship between events a and b, which complicates the proof. There is also mention of the need for clarity in notation to avoid confusion.
  • #31
Where are you going with this?
Assuming independence will change the problem.
We already covered that.
You don't know anything about P(a|b), so it can be anywhere from 0 to 1.
  • #32
sorry .. i dnt kw homework to prove this .. there may be a mistake some where or i dnt know nothing
Thanks for your help.. Ill try next prob
  • #33
I have already told you a few times how to prove it.
If it were true that " if P(a) =P(b) =p then P(a ∩ b) ≤ p2" then the relation would have to hold for all values of p and all a and b such that P(a) =P(b) =p.
You have shown that it is true for independent a and b, and for mutually exclusive a and b. I will also add in that it is true for certain p =1.
It is certainly not true for any a and b such that 0<p<1 and p(a|b) > p.
  • #34
rangatudugala said:
independent
also P(a/b) = P(a)* P(a ∩ b) / P(b) ---> 3
P(b/a) = P(b)* P(a ∩ b) / P(a) ---> 4
Are you sure about this?
Your notation P(a/b) means probability of a given b, right?
This implies that P(a/b) = P(a ∩ b). Shouldn't it just be P(a/b) = P(a ∩ b) / P(b)?
  • #35
P(a/b) means probability of a given b, right? yes its true
how come this possible ?P(a/b) = P(a ∩ b) / P(b)
  • #36
That's what it is.
  • #37
You have the probability of a given b, so you are only looking at the subset of the possibilities where b has already happened. If the events are independent, the P(a ∩ b)=P(a)P(b), similarly P(a|b) = P(a). Test these against the formula, and you will see how it is true.
  • #38
  • #39
rangatudugala said:
[PLAIN]https://upload.wikimedia.org/math/9/9/b/99b11ba7fe4ec33be7a129cf182a32d2.png[/QUOTE]
Your formula ##P(A \cap B) = P(A) \, P(B)## is NOT a general, true formula; it is true if and only if ##A## and ##B## are "independent" events, such as getting 'heads' on toss 1 of a coin and getting 'tails' on toss 2, or successive particle emissions from a radioactive element. There are millions of real-world examples where it is false. (Or, maybe I mis-read the intent of your post, in which case you might have left out some crucial clarifying information.)
  • #40
Do you not know that "P(a or b)= P(a)+ P(b)- P(a and b)"?
Also, way back in post #5, Ruber asked what "ab" meant and you never answered. Is it "a and b" or "a or b"?
  • #41
I hv already answered. probably you didn't see
here rewritten the question
prove or disprove the following
p(a) = P(b) = p (let say some valve, you can use what ever symbol ) then p(a ∩ b) ≤ p^2
  • · Replies 19 ·
