Statistics - Finding standard deviation of an angle
The discussion centers around finding the formula for the standard deviation of a heading angle derived from the north and east standard deviations of the positions of two points, along with their covariance and the distances between them. The problem involves understanding the propagation of uncertainty in the context of angular measurements using the atan2 function.
  • Participants explore the standard deviation calculations for east and north distances, questioning the appropriate covariance values to use. There are attempts to differentiate the atan2 function and apply the rules of uncertainty propagation. Some participants express uncertainty about how to handle the covariance in their calculations.
The discussion is ongoing, with participants providing insights into the differentiation of the atan2 function and the implications of covariance in their calculations. There is a recognition of the complexities involved in the problem, and various interpretations of the covariance terms are being explored.
Some participants note that one point is assumed to have zero standard deviation, which simplifies the problem. However, there is still ambiguity regarding the treatment of covariances and how they affect the overall uncertainty in the heading angle.
9988776655
Find the formula for the standard deviation (s_h) of heading angle, given the north and east standard deviation of position of two points (s_n1, s_e2, s_n2, s_e2), each point's north-east covariance (s_cov_ne_1, s_cov_ne_2) and the north and east distance between them (d_n, d_e). Simplify the problem by assuming that point 1 is known and therefore has zero standard deviation. Heading is defined as the angle from north from position 1 to position 2.
heading = atan2 (-d_e / -d_n) ← this is given in the question. (atan2 not atan squared)
https://en.wikipedia.org/wiki/Propagation_of_uncertainty
The east distance standard deviation is:
s_e = sqrt ( s_e1^2 + s_e2^2 – 2*cov); (not sure what covariance should be)
The north distance standard deviation is:
s_n = sqrt ( s_n1^2 + s_n2^2 – 2*cov); (not sure what covariance should be)
The standard deviation of (-d_e / -d_n) is:
s_x = sqrt ( (-d_e / -d_n)^2 * ( (s_e/d_e)^2 + (s_n/d_n)^2 – 2*cov/(d_n*d_e) ) )
Dont know how to get the covariance of atan2(something)
atan2 (y, x) is a variant of the regular arctan function, which permits determination of the angle in all four quadrants, based on the signs of x and y individually:
https://en.wikipedia.org/wiki/Atan2
Differentiate that according to the definition of covariance and let the error propagate as usual , foundation under all this is the Taylor expansion.
http://dont%20know%20how%20to%20get%20the%20covariance%20of%20atan2%28something%29/ that according to the definition of covariance
According to Wikipedia it is required to use partial derivatives to differentiate atan2(y/x):
d(atan2(y/x)) = -y / (x^2 + y^2) dx + x / (x^2+y^2) dy
The rules for propagation are here: https://en.wikipedia.org/wiki/Propagation_of_uncertainty
I can use the rules to propagate something^2 and something / something but how do I propagate dx or dy? There does not appear to be any rules for this.
dx and dy are the uncertainties themselves !
if the error in x is dx then the error in f(x) is ##{\delta f\over \delta x} \, dx## (a.k.a. ##f'\, dx## or ##f_x dx##)
analogous with two variables: f = f(x,y) ##\rightarrow\ df = f_x dx + f_y dy\ \rightarrow df^2 = f_x^2 dx^2 + f_y^2 dy^2 + 2 f_x f_y dx dy##
If x and y are uncorrelated, this last term drops out (expectation value = 0), but when the covariance is ##\ne## 0 it stays in.
You should now see from the above that the covariance is the expectation value of ##dx\,dy##.
If your exercise mentions covariance, i should expect your textbook or lecture notes have something to say on that !:rolleyes:
If I understand this correctly, because in my example x = -d_n (the distance in the north direction between two points) then
dx = -1
We had d(atan2(y/x)) = -y / (x^2 + y^2) dx + x / (x^2+y^2) dy
To get the variance, would I just ignore dx and dy in this calculation?
how to I combine the rules for to get -y/(x^2 + y^2) dx ?
Only the basic rules are given in the wikipedia page.
Sorry for the casual (but somewhat overlapping) notation. I'll make it worse with a qualitative story later on. Have to work first ...
If you are given ##\ x\pm \Delta x\ ## and ##\ y\pm\Delta y \ ## and ##\ f(x,y) \ ##then $$ \left (\Delta f \right )^2 = \left (\partial f \over \partial x\right )^2 (\Delta x)^2 + \left (\partial f \over \partial y\right )^2 (\Delta y)^2 + 2\, \left (\partial f \over \partial x\right )\left (\partial f \over \partial y\right ) (\Delta x)(\Delta y)$$ The ##dx## and ##dy## in post #4 and #5, the ##\Delta x## and ##\Delta y## in this post: they are your se and sn : the variations in the stochastic variables ##x## and ##y##, your de and dn. ## (\Delta x)(\Delta y)## is the covariance ## {\rm cov}_{xy}##.
As per the first post:
s_e = \sqrt{s_{e1}^2 + s_{e2}^2 – 2*cov_{e1e2}}\\s_n = \sqrt{s_{n1}^2 + s_{n2}^2 – 2*cov_{n1n2}}
Where:
s_{n1} = North standard deviation of position of point 1
s_{n2} = North standard deviation of position of point 2
s_{e1} = East standard deviation of position of point 1
s_{e2} = East standard deviation of position of point 2
s_n = Standard deviation of North distance between each point
s_e = Standard deviation of East distance between each point
Using BvU's forumula:
Let\\x = d_e\\y=d_n\\\triangle x \triangle y=cov_{xy}\\\triangle x=s_e\\\triangle y=s_n \\f=atan2(\frac{-d_e}{-d_n})\\\frac{\partial f}{\partial d_e} = \frac{d_n}{d_e^2 + d_n^2}\\\frac{\partial f}{\partial d_n} = \frac{-d_e}{d_e^2 + d_n^2}
Then:
(\triangle f)^2=(\frac{d_n}{d_e^2 + d_n^2})^2(s_e)^2+(\frac{-d_e}{d_e^2 + d_n^2})^2(s_n)^2+2(\frac{d_n}{d_e^2 + d_n^2})(\frac{-d_e}{d_e^2 + d_n^2})(cov_{d_ed_n})
If one point is assumed perfectly known as given by the question, arecov_{d_ed_n} and cov_{n1n2} and cov_{e1e2} zero?
Usually, uncertainties are reported as x +- y. (+- means plus or minus). Is y the standard deviation as given in my example? Does the same formula apply to any measurement of uncertainty?
Yes. I wrote ##\ x\pm\Delta x\ ##; however, here there are more results and the uncertainties are not independent.
I would say ##\ s_{n1} = 0\ \ \& \ \ s_{e1} = 0\ ##, as well as ##\ s\_{\rm cov}_{ne1} = 0 \ ##.
My perception is that the complicated situation is simplified as follows:
where the pink ellipse indicates that the covariance is > 0.
I don't see a ##cov_{e1e2}##, a ##cov_{n1n2}## or a ##cov_{d_ed_n}## in the first post, only a ##\ s\_{\rm cov}_{ne1} \ ## (which is assumed to be zero) and a ##\ s\_{\rm cov}_{ne2} \ ##.
The simplification let's ##\ \ s_e = s_{e2}\ \ ## and ##\ \ s_n = s_{n2}\ \ ## be the uncertainties in ##\ d_e\ ## and ##\ d_n\ ## and ##\ s\_{\rm cov}_{ne2} \ ## the covariance of these uncertainties. Still, the big "Then ##(\triangle f)^2=...##" expression is correct (when you substitute the given ##\ s\_{\rm cov}_{ne2} \ ## for ##\ cov_{d_ed_n}\ ## )
-- and that ##\ s\_{\rm cov}_{ne2} \ ## is not zero !​
11K
