Calculating Heat Discharge in a Steam Engine: Efficiency and Work Rate Analysis
In analyzing the heat discharge of a steam engine operating at half its theoretical maximum efficiency, it is established that the actual efficiency is 0.5, represented by the equation W/QH = 1/2. The heat discharged, denoted as QL, is calculated using the formula QL = QH - W. Since the engine is functioning at 50% efficiency, it discharges an equivalent of 1 J/s of heat. Additionally, the theoretical maximum efficiency for a heat engine is defined as 1 - TL/TH.
kasse
If a steam engine operates at half of its theoretical maximum efficiency, and does work at a rate of W J/s, calculate how much heat is discharged per second.
emax = W/QH (Carnot)
emax = W/2QH
--> QH = W/emax
Wrong answer. What is my mistake?
emax = W/2QH
--> QH = W/emax
Theoretical max would be equal to 1, 50% would be the actual efficiency = .5 =W/QH=1/2. Heat discharged would be QL which equals QH-W. If the engine is operating at 50% efficiency, half the heat input will go to shaft work, the other half will be discharged. So this engine would discharge 1 J/s. BTW, theoretical max. for a heat engine is 1-TL/TH.
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 26 ·
