Stellar evolution path and Regression line
The discussion revolves around the relationship between surface temperature and luminosity of stars of similar mass, particularly focusing on the implications of a regression line derived from this relationship as a potential evolutionary path for stars. The conversation touches on theoretical aspects, observational data, and the Hertzsprung-Russell diagram.
  • One participant analyzed the relationship between surface temperature and luminosity of stars using a regression model, suggesting it could represent an evolutionary path for stars of similar mass.
  • Another participant referenced the Hertzsprung-Russell diagram, implying it is a fundamental tool for understanding stellar evolution.
  • Concerns were raised about the simplicity of the regression line, with some arguing that luminosity is more complex and should follow the relation L ∝ r²T⁴, indicating that both radius and temperature change over a star's lifetime.
  • Some participants noted that stars spend most of their lives at the bottom of the luminosity-temperature curve, challenging the idea that a linear regression accurately represents stellar evolution.
  • Discussion included the effects of binary and tertiary interactions on stellar evolution, introducing concepts like "Blue Stragglers."
  • One participant pointed out that while curves can be approximated by straight lines in restricted regions, this does not necessarily reflect true evolutionary paths.
  • Another participant clarified that the relationship discussed primarily pertains to main sequence stars, suggesting that the regression line does not represent an evolutionary path but rather a mass-luminosity relation.
  • There was acknowledgment of a misunderstanding regarding the nature of the main sequence line in the HR diagram, with some asserting it is not a time sequence but rather a mass sequence.
  • One participant admitted their initial claim was somewhat incorrect but sought to clarify misunderstandings in the responses they received.
The discussion contains multiple competing views regarding the interpretation of the regression line and its relation to stellar evolution. Participants express differing opinions on whether the regression line can be considered an evolutionary path and the implications of the Hertzsprung-Russell diagram.
Participants noted limitations in the discussion, including the complexity of stellar evolution and the influence of mass on luminosity, which may not be fully captured by a simple regression model. There are unresolved questions about the implications of binary interactions and the nature of evolutionary paths.
This discussion may be of interest to those studying stellar astrophysics, particularly in understanding the complexities of stellar evolution and the relationships between luminosity, temperature, and mass.
hongseok
TL;DR
I analyzed the relationship between the surface temperature and luminosity of stars of similar mass using a regression model. Through this, I was able to obtain a regression line. Since stars of similar mass show similar evolutionary paths, I believe this regression line can be viewed as a rough evolutionary path for stars of a certain mass. Is this right?
Astronomy news on Phys.org
hi :smile:
are you not aware of the hertzsprung-russell diagram ?
Luminosity should go as r2rT4 so I don't understand what this line you fit is.
Both r and T change over the lifetime of a star, but it is not as simple as going up or down a line.
In the case of stars with a mass of 0.43 to 2 times that of the Sun, the relationship is known to be (luminosity/luminosity of the Sun) = (mass/mass of the Sun)^4. Through this, the mass of the star was obtained.
I plotted stars of similar mass on Hertzsprung–Russell diagram, and confirmed the tendency of the distribution. It was similar to the stellar evolution path in my textbook.
Is this a coincidence? I really don't know.
I don't think you are plotting what you think you are plotting, This is L vs. T:
Do you see things on a line? I sure don't. I see a complicated curve. Further, such stars spend most of their lives at the bottom of this curve.
And then you have the complex results of binary / tertiary interactions, including eg 'Blue Stragglers'...
The post-AGB phase is short-lived, and the mass changes after the supernova explosion. Therefore, doesn't the scatter plot mainly consist of the process from main sequence stars to supergiants, and can appear in a form close to a straight line?
Yes.. thank you
Every curve, when looking at a small enough restricted region, can be approximated by a straight line. This is not a new discovery; it's the basis of calculus.
It sounds to me like you are just talking about "main sequence stars", the core hydrogen burning phase that most stars are in. If you restrict to most stars, therefore, you get a simpler relation than the evolutionary paths of stars as they reach the late phases of their lives, and it looks a lot like your expression. But that is how L depends on m for main sequence stars of different m, and since stars don't really change their m on the main sequence, that's not at all an "evolutionary" path, it is just the difference between stars of different mass that are not evolving much at all.
Here I think you are imagining that stars "evolve along the main sequence line", which is a common misconception. The line of the main sequence in an HR diagram is not an evolutionary path, and the "sequence" is not a time sequence, it is a mass sequence. You are seeing how L depends on m for stars of different m, that does not relate to the evolution of those stars.
No, it's not a coincidence, it has to do with the fact that radiation diffuses out from the interiors of stars in a way that depends mostly on their mass. Hence, stars that are mostly transporting energy by radiative diffusion (which includes most stars before, during, and slightly after the main sequence phase) have a close connection between their mass and luminosity, called the "mass luminosity relation." You have rediscovered this relation, which is very important for most stars, it is indeed a useful way of estimating the mass of a star based on its luminosity, but the star cannot be in a late stage of evolution.
I'm not claiming that mass changes. Rather, it was taken advantage of. Because the mass of a star does not change, it was thought that when stars of the same mass were plotted on the H-R diagram, it would correspond to their evolutionary path.
No. I had no such Imagination. I think you misunderstood what I said.
I admit that my initial claim was somewhat wrong, but I am replying because I think there is some misunderstanding in your reply.
Do you still have any unresolved questions?
no. Most of it has been resolved. thank you
  • · Replies 21 ·
  • · Replies 0 ·
