What is the average acceleration of a cart with photogates 30 cm apart?
  • Thread starter Thread starter curiouspup34
The discussion revolves around calculating the average acceleration of a cart using photogates positioned 30 cm apart. The original poster provides specific time measurements from the LabQuest and expresses confusion regarding which times to use in their calculations, assuming an initial velocity of 0 m/s.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of velocity and whether it represents final or average velocity. There is an exploration of the implications of assuming constant acceleration on the average acceleration calculation.
The conversation is ongoing, with participants questioning the assumptions made in the calculations. Some guidance has been provided regarding the need to assume constant acceleration to derive certain values, but no consensus has been reached on the implications of this assumption.
There is a noted confusion regarding the use of time measurements and the nature of the acceleration (constant vs. variable), which affects the calculations being discussed. The original poster is working within the constraints of a homework assignment that requires specific units and rounding.
curiouspup34
Member advised to use the formatting template for all homework help requests
If the distance between the photogates in the diagram is 30 cm, and the times for the photogates on the LabQuest are listed as:
Blocked 0.00000
Unblocked 0.00156
Blocked 0.035
Calculate the average acceleration (in fundamental-standard units) of the cart. You should assume and initial velocity of 0 m/s and round your answer to 1 decimal place.
I know the average acceleration equation is delta v over delta t and I know how to find the change in velocity but I'm confused on what times to use.
My attempt:
Velocity=0.30m/(0.035)=8.5714m/s
Acceleration= (8.5714m/s-0m/s)/(0.035s-0s)=244.9m/s^2
Obviously, the velocity is not constant. Be specific about what velocity this is.
This would be the final velocity
Not according to the way you calculated it.
Then the average velocity? If this is so, is my issue that I need to find the final velocity because they gave me the initial already?
Yes.
You will have to assume constant acceleration (which makes the request to find the average acceleration a bit misleading).
haruspex said:
Yes.
So I would have
v final = (0.30m/.035s)(2) = 17.143 m/s
Avg acceleration = (17.143m/s)/(0.035s)=489.8 m/s^2
curiouspup34 said:
So I would have
Yes, but as I wrote you have to assume constant acceleration in order to claim that final velocity, so it is misleading to call the answer an "average" acceleration. If the acceleration is not constant then the average acceleration will not have that value.
Yeah that's true! Hm okay well I will assume constant acceleration now and go from there. Thank you for your help!
10K
10K
10K
17K
