Calculating Beam Separation in Stern-Gerlach Experiment
  • Thread starter Thread starter fluidistic
    Exercise
The discussion focuses on calculating the beam separation of hydrogen atoms in a Stern-Gerlach experiment, where the atoms exit an oven at 500 K and pass through a 0.5 m region with a magnetic field gradient of 20 T/m. The force on the atoms is given by F = -μ · grad B, and the thermal energy is calculated to be approximately 0.065 eV, indicating that the atoms are likely in the ground state, as the energy required to excite them is significantly higher. The calculated separation between the beams is approximately 0.5 mm, which is consistent with the experimental parameters provided.
  • Understanding of the Stern-Gerlach experiment
  • Familiarity with magnetic field gradients and their effects on atomic beams
  • Knowledge of thermal energy calculations, specifically using E = (3/2)kBT
  • Basic concepts of atomic energy levels and electron spin
  • Study the implications of magnetic field gradients on atomic beam separation
  • Learn about the principles of the Stern-Gerlach experiment in detail
  • Research the relationship between thermal energy and atomic excitation states
  • Explore advanced topics in quantum mechanics related to electron spin and magnetic moments
Physics students, experimental physicists, and educators interested in quantum mechanics and atomic physics, particularly those studying the Stern-Gerlach experiment and its applications.
fluidistic
In an experiment of Stern-Gerlach, a beam of hydrogen atoms exit an oven with a temperature of 500 K and goes through a 0.5m region in which there's a gradiant of magnetic field of 20 Tm^{-1} whose direction is perpendicular to the beam. Calculate the separation between the beams when they leave the magnetic field.
Why is it valid to assume that the hidrogen atoms are in ground state?
F= -\mu \cdot \text{grad}B.
E=\frac{3}{2}k_{B}T.
I don't understand the formula given. How can you take the gradiant of a field rather than a scalar? Do they mean the divergence?
I calculated the thermal energy for an atom and it's about 0.065 eV. I know that in the ground state, the absolute value of the energy of the atom is about 13.6 eV. But I have no idea why a very small thermal energy means that the atoms are in ground state. Maybe because the atom requires about 4 eV to get into the excited state? That must be this.
I'd like some tip on how to solve the problem. Should I include the spin somehwere?
Ok so I checked out in http://hyperphysics.phy-astr.gsu.edu/hbase/spin.html.
I used the formula (and understand it fully I think) that gives z and reached 0.25 mm. So overall the distance between the 2 beams is about 0.5 mm. It seems a bit small but I don't really have a good intuition on this. I know that the spin isn't so easy to detect so this might be right. After all 0.5 m for the applied field region is very small and 20 T is somehow near of the strongest magnetic field one can reach in a lab I think. So 0.5 mm could be right, could someone verify this?
  • · Replies 16 ·
  • · Replies 43 ·
  • · Replies 24 ·
