Stoke's equation -- particle size
  • Context: Undergrad
  • Thread starter Thread starter Kbaba
    Particle Stokes law
5 replies · 2K views
Kbaba
I want to solve stokes eq. for particle diameter in um size. Do i have to change the units to make them uniform. please help in solving the eq. by plugging these numbers.
velocity= 50 mm/h
Particle density= 2650 kg/m^3
Medium density= 1000 kg/m^3
viscosity = 1.002 mPa
Gravity= 9.8 m/s^2
As long as you work with units consistently, you cannot make anything wrong.
Some unit conversions can be necessary to get a nice unit for the result.
velocity= 50 mm/h
Gravity= 9.8 m/s^2
Your units of viscosity are incorrect, could/should be mPa*s.
Thanks for advise. Also, I want to solve the following equation for particle size (d) using stokes eq
V= g (Ps – Pw) d2/18 µ
for unknown variable (d) i rearranged the eq. as follow and took the square root of my answer. Is this the correct way to rearrange and solve this eq for particle size determination. Please, advise.
d= 18 µ V/ g (Ps – Pw)
Something went wrong with the formatting. I guess you mean this:$$V= \frac {g(P_s-P_w)d^2}{18 \mu}$$
Solved for d:$$d= \sqrt \frac{18 \mu V} {g(P_s-P_w)}$$
Sure.
I would recommend that you use dimensionless variables. It will greatly simplify your calculations if you are planning to find the flow profile.
