Stokes theorem with vector field on cylinder-plane intersection
  • Thread starter Thread starter supercali
    Stokes
supercali
let F be vector field:
[tex]\[\vec F = \cos (xyz)\hat j + (\cos (xyz) - 2x)\hat k\][/tex]
let L be the the curve that intersects between the cylinder [tex]\[(x - 1)^2 + (y - 2)^2 = 4<br /> \][/tex] and the plane y+z=3/2
calculate:
[tex]\[\left| {\int {\vec Fd\vec r} } \right|\][/tex]
in order to solve this i thought of using the stokes theorem because the normal to the plane is [tex]\[\frac{1}{{\sqrt 2 }}(0,1,1)\][/tex]
thus giving me
[tex]\oint{Fdr}=\int\int{curl(F)*n*ds}=\int\int{2/sqrt{2}*\sin(xyz)}[/tex]
i tried to parametries x y and z x= rcos(t)+1 y=rsin(t)+2 z=1/2-rsin(t)
but it won't work
Would x = 1 + 2 cos(t), y = 2 + 2 sin(t) and z = -1/2 - 2 sin(t) do the trick?
i wonder if it is allowed given we have to do a multiple integral needing 2 variables
using green or stokes is the same thing green is just a private solution of stokes and if you use it you are still stuck with that sin(xyz)
See what Halls answered you in the other thread.
