Stone falling past a 2.2 m window in 0.28 s
4 replies · 8K views
teatime95
A falling stone takes 0.28 s to travel past a window 2.2 m tall.
From what height above the top of the window did the stone fall?
So from this problem I think I have these variables:
vo = ? (or 0 because falling usually indicates 0 for an initial velocity?)
yo = 0
y = 2.2m
t = 0.28s
a = -9.8m/s^2
Kinematic equations:
y=yo+vo*t + 1/2*a*t^2
v^2 = v^20 + 2a(y-y0)
[/B]
I originally tried to use the first equation above, and solve for vo if I assumed it was not equal to zero.
So I isolated vo and got,
vo = -2.2 + 1/2(-9.8m/s^2)(0.28s)^2 / -0.28s
vo = 9.229m/s
After which I tried to substitute that value in my second equation which also didn't give me the correct answer for height (which i think is the new yo)
My textbook gives me the final answer but not the steps that it reached to get to it.
I have included the final answer here in white ink (so highlight to read) In case anyone wants to check their work or work backwards: 2.1m
I feel like my process and identifying my variables given correctly is wrong and I'm at that point where I am confusing myself repeating this question.
Guidance would greatly be appreciated,
Thank you all!
Newbie in Physics
That's an OK method. But redo it more carefully.
teatime95 said:
yo = 0
y = 2.2m
Since the stone is falling, that final value of y must be negative.
Is my math wrong here^ am I isolating for the correct variable?
If I change 2.2 to -ve I still get the same number -9.229, and I am still unsure what I do after?
I get a different value for v0.
Show what you've put into this equation:
Don't isolate v0 yet, just show what you have for the values in that equation.
Check your signs.
If downward is negative then both V0 and g have negative signs, they both end up with negative signs in your final equation for V0.
