Storing Power in a Spring - Get Help Now!
  • Thread starter Thread starter Stephni
    Power Spring
The discussion focuses on storing energy in a spiral power spring using a solar-powered motor, with the goal of releasing that energy to a dynamo for electrical conversion. The potential energy in a spring can generally be calculated using the formula PE=1/2kx^2, but for a spiral spring, which doesn't compress or extend, the angular form of Hooke's Law is more applicable. The energy stored in a torsional spring is given by PE = 1/2κθ^2, where κ is the torsion coefficient and θ is the angular displacement. Caution is advised against over-winding the spring, as excessive tension can lead to friction that diminishes energy release. Understanding these principles is crucial for effectively utilizing a power spring in energy storage applications.
Stephni
Hi,
I'm doing a project where I need to store energy in a spring with the use of a motor powered by solar energy. The energy must be stored and after a while released to a dynamo which converts the energy to electrical energy. I would like to use a spiral power spring, but I can't find any formulas on how to compute the amount of energy stored in such a spring. Please help, any other suggestions will also be much appreciated.
Thank you!
well the potential energy stored in a spring can be calculated using PE=1/2kx^2 where PE is potential energy, k is the spring constant and x is the amount of compression or extension (length).
Power is work over time...
Thanx, but a spiral spring does not extend or compress, it just gets wound up more tightly, like the spring in a watch. What equation will I use in this case?
I would image that
k = f(d\theta)
The energy stored in a compression (or tension) spring with a spring constant is determined by integrating the spring's force constant times distance.
Hooke's Law:
F = k*x
So:
PE = \int k*x dx = \frac{1}{2}k*x^{2}
For a torsional spring if you know the spring's torsion coefficient, a similar calculation can be used with the angular form of hooke's law:
Angular Hooke's law:
\tau = \kappa*\theta
PE = \int \kappa*\theta d\theta = \frac{1}{2}\kappa*\theta^{2}
Where Kappa is the spring's torsion coefficient, and theta is the displacement in radians. Kappa's units would be Newton-Meters per Radian.
http://en.wikipedia.org/wiki/Torsion_spring
One thing to watch in using a power spring (like a watch spring) is not to let it get wound too tight. If it is over wound, the leaf to leaf friction will hinder the unwinding action and absorb some of the stored energy, thus robbing you of some of the input effort.
The V = (1/2) K theta^2 law works just fine for a power spring.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
