Streamlines from a complex potential
  • Thread starter Thread starter Cloruro de potasio
    Complex Potential
The discussion revolves around the challenge of determining the correct lines from a complex potential expressed as $$ \log \frac{(z-a)}{(z+a)} $$, with a focus on the equation involving $d$ and the variables $x$, $y$, and $a$. The poster expresses difficulty in identifying the types of curves represented by their derived equation. There is a request for clarification on the term "clapping" used in their explanation, as it may not be universally understood. Additionally, suggestions are made to visualize the problem through plotting. The conversation highlights the complexities of working with logarithmic functions in complex analysis.
Cloruro de potasio
Given a complex potential of the form $ ilog \frac{(z-a)}{ (z + a)} $, determine the current lines.
${Psi = im(w)$
I've been trying this problem for a long time. By operating the lower part of the logarithm and clapping the real and imaginary part of the logarithm, I have come to the conclusion that the correct lines must be those in which it is true that:
$ d \ frac {(x ^ 2 + y ^ 2-a ^ 2) ^ 2 + 4y ^ 2a ^ 2} {(x + a (^ 2 + y ^ 2))}$
However, I am not able to operate this to get what kinds of curves it is.
complex potential of the form $$ \log \frac{(z-a)}{ (z + a)} $$, determine the current lines
Correct ? What is ##ilog## ?
You should preview your posts and fix things before posting.
In MathJax on PF, displayed math is enclosed in $$ and in-line math in ##
equally:
Relevant Equations: $${\Psi = im(w)}$$
backslash, uppercase Psi, curly right brace missing
And: what is ##w## ? And ##im## can be ##i## times ##m## or ##\operatorname {Im}##
Instead of describing what you did, please post what you did. Not everybody understands what you do when you use the term 'clapping' ?
$$ d \frac {(x ^ 2 + y ^ 2-a ^ 2) ^ 2 + 4y ^ 2a ^ 2} {(x + a (^ 2 + y ^ 2))}$$
Help us to understand this conclusion.
You could make a plot .. :rolleyes:
Ah, I see this was posted on April 1 :cool: --- any comment to add ?
[edit]for completeness: I'm not a native english speaker either.
  • · Replies 20 ·
