Stresses when a broom jams a spinning pulley
1 reply · 3K views · last reply
goonking
A pulley-and-shaft is connected to a motor which applies torque to spin the pulley as shown below:
3D CAD model of a belt-driven shaft test rig on a base plate: a large pulley on a pillow-block bearing, a motor at the left end, and a coupled drive at the right end.
Now imagine someone jams machine by sticking a broom into one of the holes of the pulley.
I would imagine there would be normal stresses at the hole (location of jam) and torsional stress on the shaft (from the motor attempting to continue turning), but magnitudes of these stresses would depend on factors like radius of the shaft, distance of holes from the center of the pulley, length of shaft, etc.
Are my assumptions reasonable?
  • 3D CAD model of a belt-driven shaft test rig on a base plate: a large pulley on a pillow-block bearing, a motor at the left end, and a coupled drive at the right end.
In order to jam the pulley, you need to apply a torsional stress on the pulley. In this case, you apply normal stress on the holes (which is torsional on the pulley) and torsional on the shaft, I agree.
I suppose the moment of inertia (of pulley and shaft) is the key in this case. The biggest torsional stress will be applied in the object with the biggest moment of inertia.
The moment of inertia depends on distribution of mass, the total mass, the geometry and the dimensions of the object.
The normal stress that is applied on the specific hole (in which you stick the broom) depends on the distance from the center of the pulley. When you apply this stress near the center, it must be bigger, because radius is smaller there.
