String theory and zeta function z(-1)
The discussion revolves around the implications of the Riemann zeta function evaluated at s=-1, particularly the claim that the sum of all positive integers equals -1/12, as popularized in various online videos. Participants explore how this result relates to string theory and what changes might occur if the sum were instead considered to be infinity. The conversation touches on theoretical concepts, mathematical reasoning, and interpretations of divergent series.
  • Some participants reference the popularization of the -1/12 result in videos, questioning the validity of the calculations and suggesting that the sum could be infinite instead.
  • One participant explains that the -1/12 result is linked to energy levels in string theory, requiring specific dimensional properties to hold true.
  • Another participant emphasizes the importance of analytic continuation in understanding the zeta function, arguing that the zeta function evaluated at -1 equals -1/12 due to this mathematical technique.
  • There is mention of alternative mathematical frameworks, such as the 2-adic number system, which can provide convergence for the series in question.
  • Some participants express uncertainty about the correctness of the interpretations and seek clarification or more accurate explanations.
Participants do not reach a consensus on the validity of the -1/12 result or its implications for string theory. Multiple competing views regarding the nature of the sum of all positive integers and the properties of the zeta function remain present.
Discussions include references to specific mathematical properties and definitions that are not fully resolved, such as the conditions under which the sum of the series may be considered valid or the implications of different mathematical frameworks.
pcm81
Over the last couple of years there has been allot of traffic on youtube about the sum of all positive integers being equal to -1/12 as is explained in numberphile video. Some argue that their calculations are wrong and the sum really is infinity. In their original video numberphile shows a string theory book that is referencing this result. My question is: what would be different in string theory if sum of all positive integers and with it the value of Riemann zeta function at s=-1 is not -1/12 but is infinity? Loooooooooong time ago i got am M.Sc. in physics; but they did not teach string theory back then; so feel free to use physics technical lingo in your answer; i simply do not know enough about string theory itself...
I should add that I watched the 10 lecture series from Leonard Susskind posted on youtube by Stanford; but that is basically all that I heard of in regards to string theory.
The -1/12 result is an energy level that is supposed to come out at -1, there is a factor of 2 involved as well making it 24 times too small. The reasoning is that 24 dimensions are needed to make this number -1. The 26 dimensions of boson string theory come from these 24 plus 1 from the infinite momentum frame in the direction of travel for the string, plus 1 for time. That's a pretty lay explanation but since you hadn't received anything I thought I'd have a go.
In this case the sum of the infinite series relies on the function having certain properties (Herglotz?), one of which is that the function must got to zero at infinity. All of these properties affect the final sum of the series. Carl Bender does an excellent set of lectures on Youtube explaining how series are summed in Perturbation Theory.
Cheers
Are you serious about this?
Sort of. The OP said he had been watching Susskind and this is the kind of reasoning he used in the video, it may not be entirely correct but the OP hadn't had any responses so I thought I would bump it. It is a bit of a vague memory as I watched it some time ago. I'd be interested in a better or correct answer as would the OP.
Cheers
Thank you both for replies. Found Carl Bender videos on youtube, but havn't seen the part about zeta function yet.
Rather than ask what would happen if the series "equaled" infinity, let's think about why it shouldn't equal infinity.
There is a YouTube video by 3Blue1Brown on analytic continuation with regard to the zeta function that I think better explains the -1/12 result. Normally, we say an infinite series equals a finite value [itex]a[/itex] if the sequence of partial sums approaches [itex]a[/itex]. Note that you can't use this definition of equality for a diverging series since the sequence of partial sums blows up. However, you can uniquely analytically continue some complex functions, that is, define a new function within the problem region that meshes very nicely with the well-behaved region. In a sense, it is not that the zeta function function evaluated at -1 that equals -1/12, but that the analytically continued zeta function evaluated at -1 that equals -1/12.
There is another way to make sense of this result using a 2-adic number system. Astonishingly, in this system, the series actually does converge. There are even some flavors of quantum mechanics that base their mathematical framework off p-adic number systems since these odd sums appear so often. 3Blue1Brown may touch on that in the video; I can't remember.
  • · Replies 43 ·
13K
  • · Replies 21 ·
  • · Replies 26 ·
10K
  • · Replies 41 ·
15K
