Stripping ions from exchange resin
6 replies · 2K views · last reply
Strange_matter
TL;DR
I want to remove the hydrogen ions from a cation exchange resin. I believe it uses polystyrene sulfonate.
I want to strip the hydrogen ion from a cation exchange resin. Would it be feasible to do this using hot water? I've tried using water at somewhere above 130 degrees Fahrenheit I believe, but I didn't see any immediate decrease in pH. I believe the resin uses polystyrene sulfonate. Should I use boiling water? I'm concerned about degrading the resin. I want to use the deionized resin to remove the sodium from sodium bicarbonate. It would also be nice to be able to use the solution of hydrogen ions as well.
Somehow I don't get what you say. Ions are not "stripped" but replaced. What do you want to replace H+ with using just water?
Resin that adsorbed metal cations can be regenerated by using an acid - H+ will replace the cations. You can get the same effect with copious amounts of water - cations will get replaced with H+ from water autodissociation (although amount of water required makes this process unpractical).
So, back to my question: what do you want to replace H+ with using just water?
That is typically how it works, but couldn't I in theory remove the hydrogen from the resin? There should be some degree of dissociation, and I believe polystyrene sulfonate should be a fairly strong acid. I don't want to replace the hydrogen with other cations, as is typical.
So what then? Are you expecting to get a solution full of unbalanced H+ ions, and a resin full of unbalanced sulfonate anions? Good luck with that!
In theory there should be some dissociation of ions, and I can exchange water once it reaches equilibrium to continue removing hydrogen ions. I want to use hot water to encourage dissociation, but I'm unsure why I'm not seeing a decrease in pH.
Best to recheck post #3 what @Borek said.
