Why Do Stronger Bonds Mean Lower Energy?
  • Thread starter Thread starter MotoPayton
    Bond Energy
The discussion revolves around the relationship between bond strength and potential energy in chemical reactions, specifically focusing on exothermic and endothermic processes. Participants explore the implications of energy changes during bond formation and breaking, questioning how stronger bonds can correspond to lower potential energy.
  • Some participants assert that in exothermic reactions, stronger bonds in the products imply a release of potential energy, which is converted to thermal energy.
  • Others express confusion, suggesting that if products have lower potential energy, the bonds should be weaker, challenging the conventional understanding.
  • A participant proposes that potential energy should be viewed as energy not utilized, implying that higher potential energy correlates with weaker bonds.
  • Another participant discusses the conservation of energy, stating that if bond formation releases energy, it requires an equivalent amount to break the bond, indicating a relationship between bond strength and energy changes.
  • Some participants highlight that in endothermic reactions, adding heat energy increases the potential energy of the system, which they argue should strengthen the bonds, leading to further confusion.
  • A later reply clarifies that weaker bonds correspond to greater distances between atoms, which is associated with higher potential energy configurations.
  • One participant explains that lower potential energy configurations are more stable, suggesting that stronger bonds are linked to lower potential energy states.
  • Another participant summarizes that as potential energy increases, the distance between atoms grows, resulting in weaker bonds.
Participants generally do not reach consensus, as multiple competing views remain regarding the relationship between bond strength and potential energy. Confusion persists about the implications of energy changes in exothermic and endothermic reactions.
Participants express uncertainty about the definitions of potential and kinetic energy, and how these relate to bond strength in different types of reactions. There are unresolved assumptions regarding the interpretation of energy changes during bond formation and breaking.
MotoPayton
Stronger bond= lower energy? why?
"In an exothermic reaction, some of the potential energy stored in the chemical bonds is being converted to thermal energy via kinetic energy(heat) In this exothermic process, the bonds in the products are stronger than those of the reactants."
This does not make sense to me at all. If there is less potential energy in the products shouldn't the bonds be weaker. I visualize a strong bond as having a higher potential energy
since the bonds are stronger and thus have more energy between the two atoms. Can someone please clarify because what seems logical is not true.
I am equally confused on endothermic reactions. The bonds should be stronger as heat energy is flowing into the system.
Yet the textbook clearly states :"In an endothermic reaction the bonds of the products will be on average, weaker."
Higher potential energy equals weaker bonds?
its the other way around,
visualize potential energy as something that is there but is not used (which makes it pointless for this specific reason). this means that if an object has a greater potential energy then it would have less kinetic energy, thus making it weaker.
SO you need to have more kinetic energy for the bond to be stronger.
physics would help you understand that even more: consider a ball on a top of a cliff. potential energy let's say is 100 which makes kinetic energy 0. as the ball starts to drop, the kinetic energy will start to increase and the potential energy will (obvi) decrease.
(i hope i answered you question, but i tried :) )
I completely understand the difference between potential and kinetic energy. But if you were to add heat energy to a system in an endothermic reaction shouldn't the atoms gain potential energy and kinetic energy. Thus making the bonds stronger so if they were to react again it would be able to give off its energy in the form of heat. If the molecules don't have stronger bonds then how is it possible that they have more energy.
I guess I am not getting it yet...
Consider the plot here of the interaction energy between two atoms (y-axis) as a function of the distance between the two atoms (x-axis)
As the two molecules approach each other, the interaction energy between them decreases (becomes more negative, at least until the molecules get too close and start to repel). This is in line with other systems with potential energy. For example, as Maz88 noted, as a ball rolls down a hill (i.e. moves towards the Earth's center of mass), the ball's potential energy decreases. As a negatively charged object moves toward a positively charged object, the Coulomb potential decreases. This reflects the important principle that things in the universe tend to act to minimize their energy.
Why do molecules that lose more potential energy in bond formation have stronger bonds? The answer has to do with the conservation of energy. If your atoms release 20 kJ of energy when they form a bond, then it must necessarily require 20 kJ of energy to break the bond.
Basically, bond formation releases heat energy while bond breaking requires heat energy. The more heat energy you release when forming a bond, the more heat energy is required to break the bond. Let's say that two atoms with no bonds between them has zero potential energy. When the atoms form a bond, they release 20 kJ of heat energy, so because of conservation of energy, we know that the bond must have a potential energy of -20 kJ. In order to break the bond, we need to separate the atoms again. Since we said that the atoms have 0 kJ of potential energy when separated, breaking the bond would require the addition of 20 kJ of heat energy. Therefore, we say that the bond strength is 20 kJ.
Let's say that we add 5 kJ of heat into the solution to rearrange the atoms. Well, let's do some math to add the heat energy to the potential energy of our molecules: 5 kJ + (-20 kJ) = -15 kJ. Now, our rearranged molecule has a bond strength of only 15 kJ. Therefore, adding heat energy to the molecule via an endothermic reaction weakened the bond.
Ok, I think I understand.
In an endothermic reaction, the system gains potential energy in the form of heat. Because the atoms have more kinetic energy and are moving faster they have the ability to get further away from each other. Because they are further away from other the coulomb force between the two atoms is less, thus they have weaker bonds.
Is that correct. Sorry, I really need to understand things completely before I move on.
It's a little bit counterintuitive because of conventions. A bound state is a lower potential energy configuration compared to that of the unbound constituents. However, bond energy is defined to run in the opposite direction, namely it's the energy that's released in going from the unbound state to the bound state.
The main point is that lower potential energy configurations are in a real sense more stable than higher potential energy configurations. For a simple example, consider a H-atom in the 1s state vs a 2p state. The 1s state is the ground state, the lowest potential energy configuration. The 2p state is a higher potential energy state and is unstable against decay to the 1s state via photon emission.
A stronger bond is a lower potential energy configuration, in accord with it being a more stable configuration. A reaction that leads to a stronger bond will release an amount of energy equal to the difference in bond energies as heat. If a reaction consumes a net amount of heat, we've raised the potential energy of the system and can conclude that the bonds in the product are not as strong as those in the reactants.
Ok, after about 2 hours I think I have my brain wrapped around this. So as potential energy goes up the distance between the atoms is greater and thus have weaker bonds.
(2 threads merged)
35K
15K
