Structs vs. Classes: Which is More Powerful in C++?
  • Context: C/C++
  • Thread starter Thread starter Vanadium 50
    Classes
8 replies · 2K views
Staff Emeritus
Education Advisor
Dearly Missed
Moderator's note: thread split off from https://www.physicsforums.com/threa...cept-its-parameter-by-reference-in-c.1049624/
Mark44 said:
Minor point, but copy constructors aren't relevant to C. They are relevant in C++, so I've edited your thread title.
That is true, but I am continually surprised and impressed about how much C++ is in C if you just know where to look, "struct" has almost as much power as "class".
So long as we are niggling, C/C++ is always call by value. When you call "by reference" you are actually calling with the value of that reference. But f(x) will not change x, and f(&x) will not change &x - but can change x.
Right, with the only difference being that struct members are public by default, while class members are private by default.
Vanadium 50 said:
So log as we are niggling, C/C++ is always call by value. When you call "by reference" you are actually calling with the value of that reference. But f(x) will not change x, and f(&x) will but change &x - but can change x.
Yes, I'm being fast and loose by talking about "reference" parameters. C, C++, etc. simulate reference parameters via pointers. In f(&x), the address of x doesn't change, but what's at that address can change.
Is that true? Can structs inherit?
Yes.
Here's some example code. The two structs represent two-dimensional and three-dimensional points, respectively. The ThreeDPt struct inherits the TwoDPt struct. I could have added some struct methods, but didn't do so.
C++:
struct TwoDPt
private:
    int x, y;
public:
    TwoDPt()
        x = y = 0;
    TwoDPt(int xi, int yi)
        x = xi;
        y = yi;
struct ThreeDPt: TwoDPt
private:
    int z;
public:
    ThreeDPt() :TwoDPt()
        z = 0;
    ThreeDPt(int xi, int yi, int zi) :TwoDPt(xi, yi)
        z = zi;
int main()
    TwoDPt P;
    ThreeDPt Q;
    TwoDPt P1(1, 2);
    ThreeDPt Q1(2, 4, 6);
After execution, P and Q hold (0, 0) and (0, 0, 0), respectively.
P1 and Q1 hold (1, 2) and (2, 4, 6), respectively.
Reply
I continue to be impressed by the power of struct.
There was a thread about structs vs. classes, maybe a year ago. Apparently structs are used most often for collections of POD (plain old data), even though they could also include their own struct methods.
That's pretty much how I use structs and classes. Structs are just for data that "goes together". but classes are smarter. I also use classes if I might want to change the internal storage: e.g. a Vector might be store internally in a rectangular basis and I might want to change it to cylindrical.
Structs are especially nice as POD when kept as simple aggregates which gives a nice set of standard functionality with minimum code. For instance, after we got designated initializers in C++ 20, which fixed the main code smell inherent with anonymous positional initialization, I find myself using them more and more.
Arguing about the thread split may be a meta-meta-meta issue but I would argue that what features of the language should be used is at least as important as being able to cobble something up that doesn't throw a syntax error.
