bumclouds
- 24
Hey guys,
I have an assignment, which is to Solve Schrödinger's equations, for a certain potential distribution, which can be divided up into three regions.
A solution for one of the regions is of the form: Ae^{kx}
If you substitute this into Schrödinger's equation (time independent, one dimension) and solve for k, you get this:
Schrodingers:
\frac{-h}{2m} \frac{d^{2}}{dx^{2}} \Psi (x) + Vo \Psi (x) = E \Psi (x)
Solve for k:
k = \frac{\sqrt{2mE}}{h}
I know this part is right because I've seen it written on the board a couple of times, and it's also what I get on paper.
But then there's the next bit, which I don't get. Apparently it's 'normalising k' which I just don't get..
k\overline{^}\overline{} = \frac{\sqrt{2mE}}{h}.\frac{L}{2}
[E] = \frac{\pi^{2}h^{2}}{2ML^{2}}
k_hat = \frac{L}{2} . \frac{\sqrt{2m}}{h} . \sqrt{E}
k_hat = \frac{L}{2} . \frac{\sqrt{2m}}{h} . \sqrt{\frac{E[E]}{[E]}}
k_hat = \frac{L}{2} . \frac{\sqrt{2m}}{h} . \sqrt{[E]} \sqrt{Ehat}
k_hat = \frac{\pi}{2} \sqrt{Ehat}
None.
If I rearrange k = \frac{\sqrt{2mE}}{h} and make E the subject,
I get ..
E = \frac{h^{2}khat^{2}}{2m}
and maybe this is where I go wrong.. because I assume E = [E] ?
Subtituting [E] into the second last step in section 2 above yields:
khat = \frac{L}{2} khat \sqrt{Ehat}
and that doesn't equal the last step >_<
EDIT: ahh.. if I use their definition of [E], [E] = \frac{\pi^{2}h^{2}}{2ML^{2}}
I arrive at the right answer..
so how did they come up with [E] = \frac{\pi^{2}h^{2}}{2ML^{2}}??
Schrodingers:
Solve for k:
None.
I get ..
