Confused About Calculating Period in Circular Motion?
The correct formula for calculating the period T of an object in circular motion is T = 2π√(m₁r/(m₂g)), where m₁ is the mass of the disk, m₂ is the mass hanging from the string, r is the radius of the circular path, and g is the acceleration due to gravity. The initial confusion arose from incorrectly using the angular velocity ω instead of the derived formula for T. The relationship between centripetal force and gravitational force was clarified through the application of Newton's Second Law.
  • Understanding of circular motion dynamics
  • Familiarity with Newton's Second Law
  • Basic knowledge of gravitational force
  • Ability to manipulate algebraic equations
  • Study the derivation of centripetal acceleration formulas
  • Learn about the relationship between angular velocity and linear velocity
  • Explore the concept of gravitational force in different contexts
  • Investigate practical applications of circular motion in engineering
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for clear explanations of these concepts.
planck42
EDIT: I figured out what I did wrong. T=\frac{2{\pi}r}{v}, not \frac{2{\pi}r}{\omega}. Now it all falls together.
A small disk of mass m_1 on a frictionless table is
attached to one end of a string. The string passes through a hole in the table and an attached narrow, vertical
plastic tube. An object of mass m_2 is hung at the other end of the string. A student holding the tube makes the
disk rotate in a circle of constant radius r, while another student measures the period T(if this is too hard to mentally picture, there is a diagram in the attachment). Derive the equation
T=2\pi\sqrt{\frac{m_{1}r}{m_{2}g}}
a_{C}=\omega^{2}r
First, it is apparent that T=\frac{2{\pi}r}{\omega}. So the question boils to what \omega is. Applying Newton's Second Law in the radial direction gives m_{1}\omega^{2}r=m_{2}g. This simplifies to \omega=\sqrt{\frac{m_{2}g}{m_{1}r}}. Agh! There's an extra r in my answer!
Centripetal force acting on the rotating disc is m1*ω^2*r. It is provided by the weight of m2.
So m2*g = m1*4π^2/T^2*r
Now solve for T.
I had figured it out before you posted, rl.bhat. Thanks for offering help anyway.
  • · Replies 28 ·
  • · Replies 17 ·
