Stupid Question about Hetero/Homogeneous mixtures
  • Thread starter Thread starter Saladsamurai
    Mixtures Stupid
The discussion revolves around the classification of salt and sand as heterogeneous or homogeneous mixtures. Participants explore definitions and examples related to mixtures, compounds, and the properties of materials in both macroscopic and microscopic contexts.
  • Some participants assert that salt is a compound, not a mixture, which complicates its classification as homogeneous or heterogeneous.
  • Others propose that salt can be considered heterogeneous due to the distinct areas occupied by sodium and chloride ions within a crystal structure.
  • A participant suggests that pure salt is homogeneous because it maintains a consistent stoichiometric ratio of Na and Cl across samples.
  • Another viewpoint emphasizes that a mixture is homogeneous if it consists of a single phase, while heterogeneous mixtures contain multiple phases, using examples like oil and water versus water and alcohol.
  • Some participants express confusion over the definitions and classifications, indicating a lack of clarity in the explanations provided.
  • There is a discussion about the homogeneity of other materials, such as brass and steel, with some arguing that they are homogeneous on a macroscopic level but may be heterogeneous microscopically.
Participants do not reach a consensus on whether salt is a homogeneous or heterogeneous mixture, with multiple competing views presented throughout the discussion.
Some participants highlight the importance of definitions and the context in which mixtures and compounds are discussed, indicating that the classification may depend on specific conditions or interpretations.
Saladsamurai
I was just asked "Are salt and sand heterogeneous or homogenous mixtures?" I can see that sand is heterogeneous, but why is salt heterogeous?
Casey
Chemistry news on Phys.org
i normally think of heterogeneous and homogeneous this way
homogenous: think of it as 2 boys (same gender)
heterogeneous: boy and girl (different genders)
please don't laugh lol
so salt is heterogeneous cause u see different particles (color wise w.e.)
but salt, its all the same white crystals or w.e. so thay makes it heterogeneous
ya this isn't the greatest explanation chemistry wise but it helps me remember!
hope it helped bud :-)
I think you mixed up something.. . . I can't make heads or tails of your explanation. Thanks though!
Salt isn't a mixture, it's a compound.
Well, the book wants to know if salt is homogeneous or heterogeneous.
Oh, well then I'd guess heterogeneous because the sodium and chloride ions occupy distinct areas (and thus distinct properties) within the packing structure of a salt crystal.
Interesting. I think that answers it then. It was a question in my girlfriends text and they said the answer was heterogeneous too. . . but I just couldn't see why and it was driving me nuts! Thanks
Casey
The question is if sand, or salt is a homogeneous/heterogeneous mixture? About salt, If he intended "grains of salt mixed with air", then it's a heterogeneous mix, but if you consider a single grain it's not a mix at all since it's a pure compound. In general, when you have 2 or more different compounds (and so a mix), the mix is homogeneous if it's formed by a single phase and so is a solution, heterogeneous if two or more phases. Ex: water and oil forms two separate phases (even when one of them is finely emulsionated into the other); water and alcohol instead forms an only phase (homogeneous mix) because they forms a solution.
About sand...i live the answer to you.
Casey
I would say pure salt is a homogeneous substance. No matter how much of it you have, you have equal amounts of Na and Cl. There are well-defined intensive quantities (density and specific heat, for example) that do not vary depending on where you took a small sample of salt.
It doesn't matter if you have equal amounts of Na and Cl; in other compounds (e.g. water) you don't have but they are still homogeneous (NON mixtures); every pure compound in one only phase is homogeneous.
Well, yes.. but that's not what I meant. In any homogeneous compound, regardless of how much you have, you retain the stoichiometric ratio of the components. This is not true for things like sand or concrete.
A piece of solid brass is homogeneous or not, for you?
That's an interesting question. I would say macroscopically it is homogeneous. I don't know enough about the microscopic structure to say anything else. Steel compounds (cementite, austentite, etc) are heterogeneous on a microscopic scale.
Brass is an example of alloy which is a solid solution (with one phase only if Zn concentration is less than 37%) so it's homogeneous, but it doesn't have a specific composition.
