Sugestions to solve this equation
  • Level: Graduate
  • Thread starter Thread starter pedro_ani
7 replies · 3K views · last reply
pedro_ani
Any sugestions on how to find the solutions to this equation?[itex]y'' +\frac{b'}{b} y' - \frac{a^2}{b^2}y=0[/itex]
where [itex]a[/itex] is a constant
I assume that b is a constant as well. That's a pretty standard homogeneous linear equation; just use the standard methods (can you write out its characteristic equation?).
No, [itex]b[/itex] is a function, if it were a constant its derivative would be zero and the term with [itex]y'[/itex] would disappear
You can obtain a lot of solutions by setting b(x) = Axn and solving for y. That won't give you a general solution though.
rewrite
[itex]by''+b'y'-\frac{a^2}{b}y=0[/itex]
to the standard form:
[itex]z''=-c^2(t)z[/itex],
with
[itex]c(t)=-\frac{2a + b'(t)}{2b}[/itex]
the general solution of the transformed equation is then
[itex]z=Asin(cx)+Bcos(cx)[/itex]
Then get the solution of y by transforming back:
[itex]y=z e^{\int{\frac{b'}{2b}dx}} = z\frac{b'}{2b}[/itex]
[itex]y=(A\sin(cx)+B\cos(cx))\frac{b'}{2b}[/itex]
That's of course, assuming a,b are such that all steps are valid
Looks to me that if you substitute that in the original equation there'll be an unbalanced b''' term.
Oops, you're right, I was thinking too simple! The transformation to standard form does not lead to an expression that can be easily solved by a ricatti equation.
Actually, maple gave the following:
[itex]y=A\sinh(\int -\frac{a}{b(x)}dx) + B\cosh(\int -\frac{a}{b(x)}dx)[/itex]
hope this helps a bit...
That suggests the substitution
[itex]t =∫(a/b(x)) dx[/itex]
which works wonders :).
