What is the sum of the infinite series: log(1-1/(n+1)^2)?
The infinite series \(\sum_{n=1}^{\infty} \log(1 - \frac{1}{(n+1)^2})\) converges to \(-\ln(2)\) as confirmed by calculations using Maple. The series is not geometric, as initial attempts to express it as such failed. Instead, it can be approached as a telescoping series by rewriting the logarithmic terms, which allows for cancellation of terms. This method leads to a clearer path toward determining the sum of the series.
  • Understanding of infinite series and convergence
  • Familiarity with logarithmic properties and identities
  • Basic knowledge of telescoping series
  • Experience with mathematical software, specifically Maple
  • Study the properties of telescoping series in depth
  • Learn advanced techniques for manipulating logarithmic expressions
  • Explore convergence tests for infinite series
  • Practice using Maple for symbolic computation in series analysis
Mathematics students, educators, and anyone interested in series convergence and logarithmic functions will benefit from this discussion.
kidmode01
Determine the sum of the following series:
\sum_{n=1}^{inf} log(1-1/(n+1)^2)
Sorry for poor latex, that is supposed to say infinity.
How might we turn this into an easier function to deal with?
So far I've only proved convergence of the series. I'm not really sure where to begin. Any help is appreciated. I've ran it through maple and come out with the sum equaling -ln(2).
I thought of trying to work backwards to see if this series was some sort of taylor expansion but I failed at that. I just don't see any elementary techniques. Obviously maple spotted something I haven't lol.
Maybe it is a geometric series. If so, why not figure out the 1st and 2nd term and the find the r. You are given the first term then use the formula a/ (1-r) where a is the first term and r is the rate.
Okay,
So I worked out the first two terms:
A1 = log(1-1/4) = log(3/4)
A2 = log(1-1/9) = log(8/9)
then r = log(8/9) / log(3/4)
But then checking A3 = log(1-1/16),
A3 does not equal r*A2.
So this is not a geometric series?
It's not geometric. Your last hope is that it is a telescoping series. Is it? Write 1-1/(n+1)^2 as a single ratio and factor it up cleverly.
Defenitely not.
Try this instead:
\sum ln\left(1-\frac{1}{(n+1)^2}\right)=\sumln\left(\frac{(n+1)^2-1}{(n+1)^2}\right)=...=
=\sum ln\keft(\frac{n(n+2)}{(n+1)^2}\left)=...=\sum[ln(n)+ln(n+2)-2ln(n+1)]=
=\sum[ln(n+2)-ln(n+1)]+\sum [ln(n)-ln(n+1)]
Now stuff will cancel out, i already did more than i was supposed to.
Edit: Sorry Dick, i didn't know you were already on it!
S'ok. How could you, I hadn't posted yet. But you should start with a hint. You shouldn't steal all the fun from what seems to be a pretty clever poster. I consider 'pretty clever' to be realizing and proving that a series is not geometric.
Haha, well thanks a lot guys :) I had thought of building it into a single ratio but I thought I was only further complicating it. Thanks again.
  • · Replies 17 ·
  • · Replies 22 ·
