Sum of Infinite Series | Calculate the Sum of a Geometric Series
The discussion focuses on calculating the sum of an infinite series, specifically the series represented by 3*sigma(1/n*4^n). Participants clarify that this is not a geometric series due to the non-constant ratio between successive terms. Instead, they suggest using the Taylor series approach to transform the series into a recognizable form. Key techniques include differentiating or integrating known series, particularly the series for F(x) = ∑(x^n/n), which is essential for solving such problems.
  • Understanding of infinite series and convergence
  • Familiarity with Taylor series and their applications
  • Basic calculus concepts, including differentiation and integration
  • Knowledge of logarithmic series and their properties
  • Study the properties of Taylor series and their convergence criteria
  • Learn how to differentiate and integrate power series
  • Explore the relationship between logarithmic functions and infinite series
  • Review examples of transforming series into known forms for easier evaluation
Students in calculus, mathematicians dealing with series convergence, and educators looking for effective methods to teach infinite series summation techniques.
Kqwert
Find the sum of the series
Not sure exactly where to start. If I move 3 outside the sum I'm left with 3*sigma(1/n*4^n), which I can rewrite to 3*sigma((1/n)*(1/4)^n), which party looks like a geometric series..Any tips?
Likes Delta2
No, it's not a geometric series. The characteristic of a geometric series is that the ratio between successive terms is a constant. The ratio ##a_{n+1}/a_n## in this case is ##(n 4^n) / [(n+1)4^{n+1}]## or ##n/[4(n+1)]##, definitely not a constant.
That said, I'm not sure off-hand what trick might work here. Here's a PDF that shows some of the tricks for transforming infinite series into something that you can work with.
http://web.math.ucsb.edu/~cmart07/Evaluating Series.pdf
I think the basic hope here would be if you can use the Taylor series approach: Can you transform this into some known Taylor series, evaluated at a particular value? Then it would be that function at that value. Or perhaps the derivative of a known Taylor series? That's where I'd start looking, but I have no specific advice to give you.
Edit: I think I found one. Look at a table of common Taylor series and find one where the n-th term has an n in the denominator. You can make that work for you. That is, the n-th term of the expansion of ##f(x)## can be the same as the n-th term of this series, for a particular x.
Likes Delta2
You need to figure out what is
$$F(x) = \sum_{n=1}^\infty \frac{x^n}{n}.$$ This is actually a well-known series that appears in all kinds of calculus textbooks and which you might have see already in your studies. Even if you do not recognize it, there are some standard tricks that people use when facing such series, such as looking at the series for ##dF(x)/dx## or ##\int F(x) \, dx##.
Likes Delta2
When you use integration you can use definite integration (instead of indefinite) and integrate from 0 to t which essentially will make the constant of integration zero.
In the left hand side you ll have
$$\int_0^t \sum (\frac{x^n}{n})'dx=\sum \frac{t^n}{n} -\sum \frac{0^n}{n}$$
and in the right hand side
$$\int_0^t\frac{1}{1-x}dx=-ln(1-t)+ln(1-0)$$
I use $$log(x)=\sum_{n=1}^{\infty}\frac{1}{n}\left (\frac {x-1}{x}\right )^n$$ for ## x>\frac {1}{2}## and set
##\frac {(x-1)}{x}=\frac {1}{4}## so ##x=\frac {4}{3}##
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
