Sum of rational and irrational is irrational
The discussion centers on the proof that the sum of a rational number and an irrational number is irrational. The user initially presented a flawed proof suggesting that the sum could be rational. However, the correct proof demonstrates that if \( a \) is irrational and \( q \) is rational, then assuming \( a + q \) is rational leads to a contradiction, confirming that \( a + q \) must be irrational. The conversation also touches on the multiplicative case, noting that special consideration is needed when \( q = 0 \).
  • Understanding of rational and irrational numbers
  • Familiarity with basic algebraic operations
  • Knowledge of proof techniques, particularly indirect proofs
  • Concept of closure properties in mathematics
  • Study the properties of rational and irrational numbers in depth
  • Learn about indirect proof techniques in mathematical reasoning
  • Explore closure properties of sets, particularly in relation to addition and multiplication
  • Investigate the implications of zero in multiplicative operations
Mathematics students, educators, and anyone interested in number theory or proof techniques will benefit from this discussion.
bigchaka
Summary:: i get a proof that sum of rational and irrational is rational
which is wrong(obviously)
let a be irrational and q is rational. prove that a+q is irrational.
i already searched in the web for the correct proof but i can't seem to understand why my proof is false.
my proof:
as you can see the proof i get is that the sum is rational.
can someone explain why thi
I don't understand why you talk about ##a+q## and write about ##a\cdot q##.
Anyway. What you did is: If ##a+q=q'## then ##a\in \mathbb{Q}##. This is correct. You wrote that ##a## is irrational, but you didn't use it. Quite the opposite is true: you started with an equation where ##a## is already rational.
This is the way to prove it anyway, both additive and multiplicative:
Given ##a\notin \mathbb{Q}## and ##q\in \mathbb{Q}##.
Assume ##a+q \in \mathbb{Q}##. Then ##a+q=q'\in \mathbb{Q}## i.e. ##a=q'-q \in \mathbb{Q}## since ##\mathbb{Q}## is closed under addition. But this contradicts ##a\notin \mathbb{Q}##, hence the assumption ##a+q \in \mathbb{Q}## was wrong, i.e. ##a+q \notin \mathbb{Q}##.
Multiplication goes the same way, except that you have to deal with ##q=0## as special case where the statement is wrong. The proof needs inverse elements and ##0## has no multiplicative inverse.
fresh_42 said:
I don't understand why you talk about a+q and write about a⋅q.
Anyway. What you did is: If a+q=q′ then a∈Q. This is correct. You wrote that a is irrational, but you didn't use it. Quite the opposite is true: you started with an equation where a is already rational.
Given a∉Q and q∈Q.
Assume a+q∈Q. Then a+q=q′∈Q i.e. a=q′−q∈Q since Q is closed under addition. But this contradicts a∉Q, hence the assumption a+q∈Q was wrong, i.e. a+q∉Q.
Multiplication is the same way.
sorry my bad. it was mixed inside my head i did proofs all the day..
you are right.
You have shown "if a+q is rational and q is rational then aq is rational". Which is correct, but a+q and q both being rational implies a is rational.
I got it, thanks!
It's really hard to follow the scribble, but in general, I would attack problems of this form with an indirect proof.
... this is a case of "two out of three ain't possible".
A simple proof follows immediately from the sum of two rationals being rational.
  • · Replies 85 ·
10K
9K
