How can ln be used to solve a sum to infinity problem?
  • Thread starter Thread starter lionely
    Infinity Sum
The discussion focuses on solving the infinite series problem involving the sum \(\frac{1}{2 \cdot 2} + \frac{1}{3 \cdot 2^2} + \frac{1}{4 \cdot 2^3} ...\) which equals \(2 \ln 2 - 1\). Participants clarify the correct interpretation of the series terms and suggest using Taylor or Maclaurin series to approach the solution. The key insight is to evaluate the Taylor series of \(\ln(1+x)\) at a suitable value of \(x\) to match the series on the left. It is recommended to use \(x = -\frac{1}{2}\) to derive the necessary series representation. Ultimately, the discussion emphasizes the importance of selecting the right function and evaluation point for solving the problem effectively.
lionely
Prove the following result:
\frac{1}{2.2} + \frac{ 1}{3.2^2} + \frac{1}{4.2^3} ... = 2ln2 -1
I tried writing down the nth term of the series which is 1/(n+1)2^n
But don't know where to move after this.
The series you wrote down has as its first denominator 2.2, but the general term that you wrote down would imply the first denominator is 4. Can you confirm that those decimal points are in fact supposed to be multiplications?
You can tex multiplication with \times, or by just wrapping the thing to be squared in parentheses and putting no multiplication sign at all (which is probably the best way to do things).
Have you covered Taylor series in your class? Problems like this almost always come down to knowing the Taylor series of an appropriate function.
The dot means multiply and , I've done Maclaurin's series.
I basically know I need to try and split up the nth term into separate series and sum each one and then they'll maybe start looking similar to other series, but splitting them up is the problem.
Don't worry about splitting things up. There are two ways that you can approach this problem. One is that you can look at the series on the left and say 'gee that looks a lot like a McLaurin series of a function that I know the value of', and the other is to look at the right side and say 'if I want to express this as an infinite series I should take a certain function here and write it out as a McLaurin series'. Either way is valid and will work on this problem. So the first question is which function/McLaurin series is being highlighted in the equation that you are given?
I would say the McLaurin series of ln(1+x)? and x =1 ?
That sounds like a pretty good idea. What happens when you follow through on the algebra?
well ln(1+1) would = 1 - (1^2)/2 +(1^3)/3 ...
Oops I was wrong in my last post. As you can see ln(1+1) doesn't give you what you want. You are going to want to use the Taylor series of ln(1+x) evaluated at some point x, just not x=1
But my teacher didn't really teach me about that, so I don't think I should use it here. Is there no way to do this using Mclaurin series?
No, I mean you want the McLaurin series of ln(1+x), but the value of x you should plug in is not x=1.
What can you plug into get a series that looks a lot like the one on the left? It might not be immediately obvious that you are also getting the thing on the right, but a nice property of logarithms will save the day.
since it says 2ln2 which is ln4 should i try x=3 ? But isn't this expansion only valid for -1<x</ 1?
Do it with ln (1/2) = ln(1+(-1/2)), that is, with x=-1/2.
ehild
