SumConverge returns unevaluated in Mathematica
6 replies · 2K views · last reply
member 428835
Hi PF!
So in mathematica I am trying to see if a function converges so I type: SumConverge[2/(n*Pi) Exp[-n^2*t] Sin[n x], n]
All mathematica does here is echo back what I typed in. Is something I'm doing wrong?
Thanks!
The function you want is SumConvergence, not SumConverge. Usually, when a Mathematica function simply echoes your input that means that it cannot determine the answer.
In this case, the problem isn't the n^2, the problem is the Sin[n x]. If x is some rational multiple of pi then Mathematica can correctly determine that the convergence criteria is Re[t]>0. However, for an arbitrary x or for an x which is not a rational multiple of pi then Mathematica doesn't know, so it returns the input.
It just needs a little hint
In[1]:= Assuming[t > 0,
FullSimplify[SumConvergence[2/(n*Pi) Exp[-n^2*t] Sin[n x], n]]]
Out[1]= True
Hummm. I reboot the machine. Win7 64, MMA 9 64. Open MMA. Scrape
Assuming[t > 0, FullSimplify[SumConvergence[2/(n*Pi) Exp[-n^2*t] Sin[n x], n]]]
off the screen, paste it into the notebook, <shift><enter> and a few seconds later it replies True.
The result is the same even if you remove the 2/(n*Pi).
If you could reply with your having done exactly those steps, nothing more, and you still get echo then we can try to figure out where to go next.
Unfortunately all the work is done internally and Trace tells us nothing about where it might be going wrong.
You might try all the examples in the help pages for SumConvergence and verify that they work for you.
