Summing i*r^(i-1) from i=1 to i=n
  • Thread starter Thread starter mathvision
The discussion centers on deriving the sum of the series i*r^(i-1) from i=1 to i=n using the identity i*r^i - (i-1)*r^(i-1) = r^(i-1) - (1-r)i*r^(i-1). Participants clarify that this identity is not valid for i=1 and suggest using the derivative of the geometric series sum, specifically ∑_{i=1}^n r^i, to find the desired result. The conversation emphasizes the importance of correctly applying the identity and provides an alternative method for those restricted from using calculus.
  • Understanding of geometric series and their properties
  • Familiarity with calculus concepts, specifically differentiation
  • Basic algebraic manipulation skills
  • Knowledge of mathematical notation and summation
  • Study the properties of geometric series and their sums
  • Learn how to differentiate series to find sums
  • Explore telescoping series and their applications in summation
  • Practice deriving identities involving summations and series
Students studying calculus, mathematics enthusiasts, and anyone looking to deepen their understanding of series and summation techniques.
mathvision
I wanted to post this in the homework forum, but there's only pre-calc for math.
Question: Show that i*r^i-(i-1)*r^(i-1) = r^(i-1)-(1-r)i*r^i-1. Use this result to find the sum of i*r^(i-1) from i=1 to i=n.
I've done the first part of this question, but need some help with the second. Thanks!
This identity isn't valid for i=1, check it.
Do you mean "i*r^i-(i-1)*r^(i-1) = r^(i-1)-(1-r)i*r^(i-1)"? Otherwise, as MathematicalPhysicist said, it is not true for i= 1.
In any case, I would not use that. Are you required to?
I would note that \sum_{i=1}^n r^i is a geometric sum and that \sum_{i= 1}^n i r^{i-1} is its derivative with respect to r.
Yes it was a typo. And yes I'm required to use that result! :rolleyes:
Question: Show that
i r^i - (i-1)r^{i-1} = r^{i-1} - (1-r)i r^{i-1}
Use this result to find the sum of i r^{i-1} from i=1 to i=n.
Hi mathvision, I've edited that for you.
If this isn't pre-calc then just differentiating the geometric series as Halls suggests is the best way to do it.
If this is pre-calc and you need to do it without using calculus then you can do the following. Sum both sides of your above expression and notice that the RHS is the sum of (r-1) times the sum you are trying to find, plus a simple geometric series. Also, the left hand side completely "telescopes", leaving just the first and last terms. Basically then you can just rearrange this to get an expression for the part you are interested in.
  • · Replies 22 ·
