Monsterboy said:
Details about where to hit and the angle of decent will be helpful.
Here is a model that varies by angle. They say you get maximum rock vapor at a 30 degree angle. Rock vapor in the atmosphere causes climate chaos. A 30 to 45 degree angle should send a shower of ejected meteors raining down hundreds of kilometers away. Animals in the shower are baked well done and plants burn.
I suspect you could hit a coastline and shower the continent with flaming meteors and also send a tsunami in the reverse direction.
Monsterboy said:
Should it hit the Middle East, will the oil fields and/or natural gas reservoirs become unusable and catch fire that can never be put off ? causing an additional shortage of fuel to the world economy (which is overdependent on oil) on top of the other damages that impact will cause ?...
The oil fields are trivial in this case. Limestone is converted to calcium oxide in cement manufacturing at much lower temperatures. Earth's atmosphere has around 10
14 kg of CO
2. Your 10km comet could pack more than 10
14 kg of CO
2 itself. If it hits limestone a few kilometers deep then you could add the same order of magnitude quantity of CO
2 . The flaming meteors will burn vast areas of forest. The dust cloud blocking the Sun will cause a global plant and plankton die off. Plants hold 5 x 10
14 kg of carbon and soil 15 x 10
14kg.
The Saudi oil fields are in sandstone. Sandstone and shale has much less carbon than limestone/chalk.
Monsterboy said:
Well then, forget about supervolcanoes, I want a 10 km across asteroid to hit the Earth and cause maximum damage to the human civilization, where should it hit ?
Or, should it crash head-on in the Atlantic ocean and damage the US, Africa and Western Europe ?
You could go for both a tusnami and maximum carbon emission by hitting an island. Abaco island in the Bahamas could still shower the East Coast with debris. Many islands in the pacific are coral based.
Instead of hitting limestone you could aim for a gypsum mining area. Vaporizing calcium sulfate and ejecting it into the stratosphere should shower Earth in acid rain. Sulfer dioxide itself is an anti-greenhouse gas. In the short run sulfuric acid cools climate. Dust also blocks sunlight so you should be able to set off a nuclear winter. The cold snap will help kill the plants. Sulfur
reduces the atmosphere's ability to remove greenhouse gasses so in the long term it increases warming trends. There should be extra methane released by decaying plants. Much of the sulfur dioxide will fly over the ozone layer so should cause depletion. I have not seen any study of what lime, CaO would do to the ozone layer.
Crashing the comet near Fort Dodge Iowa you would get the sulfur, carbon/carbonate, and it would burn a lot of North America. You lose the tsunami but melting glaciers and expanding oceans should flood most European coastal cities anyway. An Atlantic tsunami would leave the Philippines and Tokyo dry. Water vapor has a short term warming capability that offsets the short term cooling from dust. Hitting the gypsum beds would whiplash the ecosystem going from a short extreme cooling to long term extreme warming.
You could consider hitting a salt deposit. The salt could kill the plants and most of the soil organisms in the fallout zone. So if the nuclear winter is not intense enough you still get adequate die off for extreme climate change.
It might be worth considering the effect of a comet containing a lot of nickel dust. Large amounts of nickle can cause cancer, liver failure and skin lesions in humans. Nickel powder is lethal to fish and algae in small quantities. Metallic asteroid dust could also have a fair amount of lead, arsenic, uranium or other heavy metals.[/QUOTE]
