Supremum/infinum/max/min concerns x axis or y axis?
  • Context: Undergrad
  • Thread starter Thread starter kahwawashay1
    Axis
The discussion clarifies the concepts of supremum and infimum in mathematical sets, specifically addressing their definitions in relation to the x-axis and y-axis. The supremum of the set of rational numbers where \( x^2 < 2 \) is established as \( \sqrt{2} \), while the infimum of the sequence \( 1/n \) approaches 0 as \( n \) approaches infinity. Additionally, it is confirmed that the supremum of the function \( f(x) = x^2 \) over the interval (-1, 3) is 9, and the minimum is 0. The distinction between least upper bounds and maximum values is emphasized throughout the discussion.
  • Understanding of supremum and infimum concepts in real analysis
  • Familiarity with rational numbers and their properties
  • Basic knowledge of functions and intervals in mathematics
  • Ability to interpret mathematical notation and inequalities
  • Study the properties of least upper bounds and greatest lower bounds in real analysis
  • Explore the concept of limits and convergence in sequences, particularly with \( 1/n \)
  • Learn about the implications of supremum and infimum in optimization problems
  • Investigate the behavior of continuous functions over closed and open intervals
Students of mathematics, particularly those studying real analysis, educators explaining supremum and infimum concepts, and anyone interested in understanding the properties of functions and their bounds.
kahwawashay1
When we talk about supremum/infinum/etc, does it mean the largest/smallest number on the x-axis or y axis??
Ok so first my professor was explaining how when x^2 < 2 , the supremum is root of 2 (so he was talking about how the domain has a least upper bound).
But then he said that when we look at 1/n, where n is 1,2,3,... , the infinum is 0...so in this case i guess he meant that the range is bounded from below (since 1/n approaches 0 as n->infinity)...but if you look at the domain, the infinum is actually a minimum and equals 1...
help me clear up this ambiguity?
An infimum is the greatest lower bound and the supremum is the least upper bound. When you're looking at the set:
A = {1,1/2,1/3,1/4,...}
sup(A) = 1. This is because 1 is an upper bound for A (every element is less than 1) and there is no upper bound that is lower than 1.
inf(A) = 0. This is because 0 is a lower bound for A (every element in A is greater than 0) and there is no lower bound that is greater than 0. If there was, call it a, you could always find an n such that 1/n < a.
I think the confusion you were having is that the infimum would be the first element in the set, but this isn't true. You need to consider all elements of the set and see what's going on.
Oh ok so i understand about the 1/n...but what my professor wrote exactly was that supremum of
\left\{x\in Q: x^2 &lt; 2\right\}
is root of two...but shouldn't it be just 2?
ohh nvm the supremum is root of two in this case because we are talking about x in Q that satisfy the condition x^2 < 2...but if we just ask for supremum of {x^2 < 2}, it would be 2?
Think about it. \left\{x\in Q: x^2 &lt; 2\right\} means the set of rational numbers such that each rational number squared is less than 2. 22 = 4. 2 is definitely an upper bound for the set, but it's not the least upper bound. (note that the supremum does not need to be in the set. In this case, the supremum doesn't need to be a rational number. It only needs to be a least upper bound) What's something else you could plug into x such that there it is an upper bound for the set, and also that it is the least upper bound?
kk thanks i get that,
so as another example just so i kno for sure i get it, if
f: (-1, 3)->R
f(x)=x^2
then the supremum is 9 and minimum is 0 ?
f: (-1, 3)->R
f(x)=x^2
If the set you're considering is f(x) = x2 for x in (-1,3), then yes.
