Surface Integral (Divergence Theorem?)
7 replies · 3K views
jegues
See figure attached for problem statement.
See figure attached for my attempt.
What I decided to do was add a surface z=0 so that S became a closed surface.
Then I preformed the integration using divergence theorem and obtained a value of 972pi
Now all I have to do is remove the portion that the surface z=0 contributes.
How do I figure this out? I'm looking at the given F and I can see that the normal for z=0 will simply be, [tex]\hat{k}[/tex] and that will be dotted with the z component of F which is,
[tex]z^{2}[/tex] but z=0 so it's going to be 0.
Is what have done the right approach?
Thanks again!
Is this a take-home exam problem?
No, I am studying for my upcoming final exam using old final exams. It was an exam problem from 2009.
Thanks again!
OK, that's good. I will try to delete another post where I asked the same question.
As for your solution. First, your surface isn't just in the first quadrant. Second, when you set up your triple integral, you don't plug the z on the surface in the integrand. The inner integral will have limits z going from z =0 to z on the surface.
I only drew the surface in the first quadrant to get an idea of what it looked like, I knew it was in all quadrants but perhaps I should do a full drawing next time.
Alrighty here's my second crack at it. (See figure attached)
Any problems?
Your setup is OK. I didn't check all your steps but at most there would only be algebra errors, if any. Looks like you're good to go...
Also do I have to think about removing the portion that the surface z=0 contributes?
I think if you were to calculate that it would be 0 anyways.
We know that the unit normal to this surface will simply be [tex]\hat{k}[/tex] dotting this with the k-component of F when z=0 will simply provide us with the integral of 0.
Is this correct?
Is this correct?
Yes. I didn't comment about that part because you were thinking correctly. If it wasn't zero you would have to account for it.
