What is the relationship between surface tension and forces?
The discussion focuses on the relationship between surface tension and forces, specifically through the derivation of the formula for surface tension using hydrostatic equilibrium. The participant successfully derived the equation $$ y = \frac{h \cdot \rho \cdot g \cdot r}{2} $$, resulting in a surface tension value of 0.0365 N/m. The conversation highlights the importance of using equilibrium of forces in calculations, contrasting it with a simpler formula provided in class, which is identified as Jurín's law. The correct application of these principles leads to accurate results in fluid mechanics.
  • Understanding of hydrostatic equilibrium principles
  • Familiarity with surface tension concepts
  • Knowledge of Jurín's law
  • Proficiency in LaTeX for mathematical expressions
  • Study the derivation and applications of Jurín's law in fluid mechanics
  • Learn about hydrostatic pressure and its implications in various fluid scenarios
  • Explore the effects of angle and curvature on surface tension calculations
  • Practice using LaTeX for complex mathematical expressions and derivations
Students and professionals in physics, particularly those studying fluid mechanics, as well as educators looking to enhance their understanding of surface tension and force equilibrium concepts.
arhzz
Determine the surface tension γ of a liquid with the help of the capillary effect. The capillary has an inner diameter of 0.5 mm and the liquid with a density of 875 kg / m3 rises 3.4 cm. To do this, derive the formula for γ from the equilibrium of forces
F = mg
Hello! To this I did what was recommended and this is what it looks like
$$ F = mg $$
$$ F = \rho * V * g $$
$$ F = \ rho * \pi^2 * h * g $$
Than for the surface tension I did the same thing to get an expression for F.
$$ y = \frac {F} {2 \pi r}$$
Than tried to get F out and than equate both of the equations, than F and pi would be on both sides so it would cancel out leaving me with this.
$$ \rho * r^2 *h * g = 2 * y * r $$
Than I tried to get the tension out so I moved everything accordingly and got this $$ y = \frac {h* \rho*g*r} {2}$$
The result should be 0,0365 N/m
Now the reason why I am posting this question is why is it recommened to use the equilibrium of forces? I tried to calculate the tension, with an equation that was given to us in class, it doenst include any forces and I got a whole diffrent result. I'd assume this is the right way to do it given the suggestion in the task itself but why? And in a situation where this "hint" wasnt given to me I'd never come to use this variant, id just do with the formula provided in class. Any insights?
Thank you!
Surely the formula that they gave you in class is the one of the well-known Jurín law https://en.wikipedia.org/wiki/Jurin's_law
Your derivation of the formula by means of hydrostatic equilibrium is correct, you just have to consider that the angle of the smallis formed by the liquid is zero, so the cosine becomes unity.
Your calculation result is correct 0.0365N / m
Check the Latex calculation of the area missing a "## r ##"
Yes that was the formula that was given to us,And your right I am missing an "r". And taht with the cosine I didnt even think about,clears things up.
Thank you!
  • · Replies 22 ·
  • · Replies 63 ·
  • · Replies 18 ·
  • · Replies 19 ·
