SUVAT equation question: When will the car collide with the lorry?
The discussion revolves around a problem involving the SUVAT equations of motion, specifically focusing on a scenario where a car and a lorry are decelerating. The car is positioned a distance d behind the lorry, which is applying brakes to come to a stop, while the car also applies brakes with a different deceleration rate.
  • Mixed
  • Participants explore the conditions under which the car collides with the lorry, questioning the setup and the assumptions regarding deceleration and stopping distances.
The discussion is ongoing, with participants providing feedback on the original poster's equations and reasoning. Some have pointed out inconsistencies in the signs of the accelerations, while others emphasize the need for clearer presentation of the work done. There is a focus on understanding the problem rather than reaching a definitive solution.
Participants note that the original poster's equations may have been incorrectly formatted or presented, leading to confusion. There is also mention of the challenges faced when using mobile devices for posting mathematical expressions.
lukegxhycj
A lorry travelling along a narrow road with speed u1
applies its brakes to give a uniform deceleration of magnitude a1
. At the same time a car, a distance d behind the lorry and travelling in the same direction with speed u2
, applies its brakes to give a uniform deceleration of a2
Part A
Show that the car collides with the now stationary lorry if a2≤ku2^2
, and find k in terms of u1 , d and a1
All SUVAT equations
s1=-u1^2/2a1
s2=-u2^2/2a2
s2>s1+d
(If distance the car stops is bigger than the distance the lorry stops plus the initial distance then they will crash)
(sub s1 and s2 in)
-u2^2/2a2 > -u1^2/2a1+d
Switch 2a2 with whole left side of equation.
-u2^2/(-u1^2/2a1)+d > 2a2
Make the (d)a fraction by multiplying denominator and numerator by 2a1
-u2^2*(2a1/-u1^2+2a1d) > 2a2
Cancel the minus time minus on the left side.
u2^2*(a1/u1^2+2a1d)>a2
K=a1/u1^2+2a1d
And it was wrong apparently
lukegxhycj said:
Homework Statement: A lorry travelling along a narrow road with speed u1
, applies its brakes to give a uniform deceleration of magnitude a2
.Part A
Requirement on deceleration
All questions in this part are answered incorrectly
Relevant Equations: SUVAT equations of motion:
v
=u
+2as
s=ut+
at
s=
u+v
t
v=u+at
(a_1)/(u_1**(2) - d*a_1*2)
Welcome to PF.
Something is really messed up in your equations. Did you paste them in from somewhere? What device and browser are you using to log into PF?
Hello @lukegxhycj ,
:welcome: ##\qquad## !​
Please read the PF guidelines
WIth a bit of ##\LaTeX## your post might look like
lukegxhycj said:
Homework Statement: A lorry travelling along a narrow road with speed ##u_1## applies its brakes to give a uniform deceleration of magnitude ##a_1##.
At the same time a car, a distance ##d## behind the lorry and travelling in the same direction with speed ##u_2##, applies its brakes to give a uniform deceleration of magnitude ##a_2##.
Part A
Show that the car collides with the now stationary lorry if ##a_2 ≤ k u_2^2##, and find ##k## in terms of ##u_1##, ##d## and ##a_1##
I agree the SUVAT equations are what you need to solve this exercise.
Sort them out with ##\LaTeX## and post your best effort at solution (required per the PF homewok rules)And:
I don't understand how
can be part of the problem statement. Can you explain :wink: ?
BvU said:
Hello @lukegxhycj ,
I don't understand how can be part of the problem statement. Can you explain :wink: ?
It is an error let me fix it also I am on my phone so I can’t use latex
Are you sure? I don't remember if I've tried it from my phone, but it seems like it should work. Have you looked at the LaTeX Guide link below the Edit window?
Welcome to PF.
Yeah sorry I meant to paste all SUVAT equations I’ve fixed it now it doesn’t have them because it messes it up
That's an expression, not an equation. Can you try to show more work on this? I'm not sure why you're having issues typing math into the forum. What kind of phone is it?
Yh this is the answer I got but it’s wrong
K=
Then you need to post your working so that we can see where you went wrong.
so that we can see where yowent wrong.
Ok
I have added the working please could you take a look at it thanks for your time
Your photos of your work are almost completely illegible, due to poor lighting and mostly faint writing. We generally discourage members from posting photos of their work for these reasons.
And just an FYI for the future, in discussion forums we usually discourage altering your Original Post (OP) with more information that is asked for in subsequent replies, because it is very confusing for folks who read the thread later. It makes our requests for more information look strange, since the extra information is in your OP by the time they read it. It works much better if you add the extra information in a new reply instead. Thanks. :smile:
I will send you a Private Message (PM) with tips for using LaTeX to post your work.
This condition is not relevant. The car can crash into the lorry before the lorry stops.
Yes sir the the question says the lorry stops before the car
lukegxhycj said:
Ok
I think you have been inconsistent in the signs on the accelerations. I see "a=-a1” but "a=a2".
Sorry can you please get an answer so I can reverse engineer what I’ve done wrong
We don’t give answers; we help you sus out errors. You fix the errors and hopefully you learn.
At top right of your first attachment I see ##a=a_2##.
##a_2## is given as a rate of deceleration, so the acceleration is ##-a_2##. You did it correctly for ##a_1##.
  • · Replies 16 ·
17K
